No reverse lights, transmission switch/sender changes?
Old May 12, 2013 | 06:50 PM
Jon B.'s Avatar
Jon B.
Default No reverse lights, transmission switch/sender changes?
Ok, so the reverse lights do not illuminate on my '03 Z when the car is in reverse. They illuminate just fine when unlocking and locking the car, so it's not the bulbs. I've done enough research to see that it's likely the switch in the transmission. Thing is, this transmission is out of a C6 (entire rear was swapped with C6 RPM stuff) and I don't know if I'll need a different one from stock. Any help is appreciated.
