tsp headers
Old May 14, 2013 | 07:02 PM
blacknyellow's Avatar
blacknyellow
Default tsp headers
What do you guys think of tsp as a brand of long tubes for a c5.
Scale of 1-10 is always helpful.
Thanks you guys
Old May 15, 2013 | 06:31 AM
baxsom's Avatar
baxsom
I have their older mild steel ceramic coated ones with 3 inch X pipe. Easy to install the headers. Passengers side dropped right in. drivers side required me to remove the coils, valve covers, alternator, and the steering linkage ( i cant remember the correct term is at the moment) the X pipe required me to make holes in the tunnel plate so the O2 sensors will clear. The new version is the same dimensions as the old only stainless steel. Id say a 6 overall to install, and since mine is mild steel a 5 on durability, fitment of the headers themselves an 8, total satisfaction. If I would have held out for the stainless id say a 8 overall, the mild steel about a 6.
Old May 15, 2013 | 09:16 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I have one of the earlier original sets also. For being ceramic coated mild steel they do get rusty. But I haven't had any weld cracks or issues otherwise. I just pulled my set off for the last time ever as I'm doing a twin turbo swap. If your interested in a cheap used 1-3/4" set with 3" off-road x-pipe and dual 3" cutouts, pm me.
Old May 15, 2013 | 10:08 AM
hamhead's Avatar
hamhead
I got one of the newer sets that I put on this past weekend (stainless steel).
For what its worth, I'm still tinkering with it in my garage because the driver side header is touching the frame. The rest of it, quality wise, is fine. And I may be able to get that side to fit with some tweaking, I just gave up for the moment.
To tsp headers
