LED lights
Old May 16, 2013 | 05:08 PM
Tim Hughes's Avatar
Tim Hughes
Cruising
Default LED lights
I installed LED lights turn signal lights. Now the turn signals are flashing rapidly. I am assuming that I need to add a resistor?
Looking for suggestions.
Old May 16, 2013 | 05:58 PM
jamieo's Avatar
jamieo
Resistors will work but I just installed an electronic flasher on mine to correct the same issue.Followed one of the write-ups on here and it was really simple and worked great.The flasher was about $10 and about 20 minutes to install.
Old May 16, 2013 | 07:57 PM
jcgunn's Avatar
jcgunn
Get a hyperflash harness from forum vendor JWM--plug-n-play works like a champ
Old May 17, 2013 | 04:17 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
To LED lights
