oil leak
Old May 18, 2013 | 12:37 PM
armon's Avatar
armon
2nd Gear
Default oil leak
i have an oil leak from the rear of the engine only in the morning on initial start up any suggestions i have had 2 upper gaskets replaced and the oil pan cover tightened.
Old Jul 1, 2013 | 01:33 AM
philcol's Avatar
philcol
I have a bad leak upon cold start up then it almost quits. What did you find on yours?
Old Jul 1, 2013 | 12:25 PM
armon's Avatar
armon
2nd Gear
nothing as yet am bringing it to a vette mechanic hopefully to get an answer. 1 mechanic said rear main engine seal the other said oi pan gasket.
Old Jul 1, 2013 | 01:26 PM
3boystoys's Avatar
3boystoys
Oil pressure sender probably leaking
Old Jul 1, 2013 | 01:43 PM
GEMcLean's Avatar
GEMcLean
Also make sure oil filter is tight.
Old Jul 1, 2013 | 06:48 PM
maxx2200's Avatar
maxx2200
Old Jul 1, 2013 | 07:27 PM
racebum's Avatar
racebum
To oil leak
