I dont get what happend
Old May 19, 2013 | 02:49 PM
schaffer C5's Avatar
schaffer C5
Default I dont get what happend
A lot of you know that I had a problem with the engine running rough in the morning. Well here is what I did over the weekend. I replaced the Radiator because it was cracked, intake manifold gasket, oil pressure sensor, Oil change, and serpentine belt. I used Royal Purple 5w30 well the tapping went away the next morning. That is the thing I don't understand. The engine runs smooth but I still hear a little squeaking from the harmonic balancer.
Old May 19, 2013 | 04:44 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Check your pulley alignment. The balancer may be starting to delaminate, and the outer ring is moving either forward, toward the steering rack, or back, toward the engine's timing cover.
Old May 21, 2013 | 12:14 PM
schaffer C5
thanks I will check that.
Old May 21, 2013 | 01:58 PM
3boystoys's Avatar
3boystoys
Probably sealed a vacuum leak with the new manifold gasket.
Old May 21, 2013 | 03:40 PM
racebum's Avatar
racebum
you spill any coolant, oil or grime on the belt or pulleys? squealing is often either a failing tensioner or oil/coolant on the belt/pulley
To I dont get what happend
