Starter Replacement with Long Tubes
Old May 23, 2013 | 06:43 PM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
Default Starter Replacement with Long Tubes
I'm curious how much a set of Long Tubes changes a starter replacement.
Does the passenger side header have to be completely removed?
Any advice would be great!
Cheers,
Old May 23, 2013 | 07:27 PM
bumble-z's Avatar
bumble-z
Most of the time when long tubes are installed, an X pipe is installed
too.
With the LG Pro (1-3/4") long tubes & 3" x pipe that I have installed,
I don't think the header would have to be removed.
I would have to remove the x pipe & then loosen all the header bolts on the passenger side to allow enough room to angle/wiggle the tubes out enough to remove the starter.
So far, I haven't had to remove or loosen the header/headers in the 8 or 9 years they have been in place.
A couple of years ago, I purchased a Thermo Tec starter heat shield that I tried to squeeze in between the tube & starter & there wasn't enough room to slide it in ...so the heat shield is setting on the shelf, gathering dust.
Old May 24, 2013 | 11:52 AM
SVTBAIT's Avatar
SVTBAIT
Thanks for the help!
Does anyone else have any experience with this?
To Starter Replacement with Long Tubes
