Headliner Adhesive
Old May 24, 2013 | 04:30 PM
Mathew702's Avatar
Mathew702
Default Headliner Adhesive
Hi All,
It's getting hot outside and I recently switched from my lexan top to the solid/insulated one. Over the years the liner has developed a sag. Yesterday it came completely off. I live in Vegas so I imagine the heat is a large factor. Can anyone suggest a spray adhesive that will hold up to the heat and wont dissolve the liner?
Old May 24, 2013 | 04:48 PM
DARRYLZO6's Avatar
DARRYLZO6
Originally Posted by Mathew702
Hi All,
3M Headliner adhesive,$17.00 a can. Home Depot. Its all good.
Old May 25, 2013 | 03:36 AM
Mathew702's Avatar
Mathew702
Thanks!
Old May 25, 2013 | 07:07 AM
DARRYLZO6's Avatar
DARRYLZO6
Thanks!
That's 3M #80 spray adhesive. After installation with the adhesive, leave the top in an open space for about 3-4 days before use. The fumes are very strong so use caution.
Old May 25, 2013 | 11:04 AM
lionelhutz's Avatar
lionelhutz
If this is a typical headliner (I don't have a solid top) then it's the foam behibd the cloth that is breaking down causing it. You'll likely have to scrape off the failing foam or really soak it in glue to have any chance of it staying up.
To Headliner Adhesive
