Oil Change Reset problem!??!
Old May 24, 2013 | 07:17 PM
triziks's Avatar
triziks
Default Oil Change Reset problem!??!
I recently did a oil change (Always do them myself.) and i hit reset on the oil percentage gauge. It it will not change back to anything other then 6% and says change oil soon. Any other options i can do to fix this?
Old May 24, 2013 | 07:22 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
did you try the press the gas pedal 3 times quickly to reset it?
Old May 24, 2013 | 07:32 PM
triziks's Avatar
triziks
No I havent i shall try!
Old May 24, 2013 | 07:45 PM
65GGvert's Avatar
65GGvert
You can reset it two ways: Hold down the reset button until it resets, don't just press. OR turn on the key, don't start engine, press accelerator to floor and release three times, turn off key.
Old May 24, 2013 | 08:53 PM
triziks's Avatar
triziks
thanks guys worked
To Oil Change Reset problem!??!
