? For those running 1.8 rockers
Old May 29, 2013 | 10:14 PM
thepitstop2010's Avatar
thepitstop2010
Default ? For those running 1.8 rockers
Looking into replacing my Yella Terra 1.7 with a set of 1.8 rockers. I am curious if anyone has made this change and has any side by side comparison dyno numbers or 1/4 mile time differences between the two?
I am getting ready to install my new Mamo ported Fast 92 and LS2 throttle body and want to install these 1.8 rockers at the same time(if I will benefit from them) before I get it tuned! Thanks in advance!
Old May 29, 2013 | 10:54 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Should bump the power up. I would guess, maybe 10hp. Make sure your springs can handle it and your PTV clearance is ok. If your cam is more than .620 lift, you may be asking for trouble. Hopefully someone will post that has been there done that. You should post your cam specs, valve springs, pistons and head gaskets to get better answers.
P.s. if you do change, pm me ill take the 1.7's
Old May 29, 2013 | 11:05 PM
thepitstop2010
Cam is Lingenfelter gt1 (.218-.229, .563-.563 113 lsa), comp 26928 springs, stock ls1 pistons, GM mls head gaskets, stock 243 heads. The 1.8 rockers will bring my lift to .596-.596.
Old May 30, 2013 | 06:30 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
They should work well with that cam. It's a mild cam. Did you consider going with a larger cam and/or pulling the heads and having them cnc ported?
To ? For those running 1.8 rockers
