Seeking advice on O2 sensor / cat / high HC content
http://forums.corvetteforum.com/c5-t...smog-test.html
I just smogged my car again earlier this month and here are the results from the past several years of smog tests.
So, of course I was happy that I passed, but there is still a high level of HC and now high NO content. So, next plan was to scan the car to check the fuel trims and O2 sensor operation. Below is a screenshot of my O2 sensor voltage at idle. I obtained this by utilizing the “Engine Link” iPhone App, using an ELM 327 wifi OBDII connector….kind of a cool product (however the graphing leaves a little to be desired since they don’t even have a scale on the graph). I have since ordered an Actron CP9185 scanner but it won’t arrive until next week.
From the data it appears that my primary O2 sensors are operating properly and cycling from about 0.2 to 0.9 V at idle. It appears that my Left downstream O2 sensor is cycling (from 0.45 to ~0.85) indicating the left catalytic converter may not be functioning properly. My right downstream O2 sensor is reading very constant at 0.45 V, indicating my right cat is operating properly.
Also, my Short Term Fuel Trims are very close to 0, and the Long Term Fuel Trims are on the positive side with a maximum of about 7-8%. From my research this doesn’t appear to be too out of whack, but it would explain why my car may be running a bit rich (hence the high HC content)?
I replaced the cats two years ago (4,000 miles). I have heard that these high flow cats don’t last very long, but 4000 miles? That doesn’t seem right.
So, is my logic correct here? I wanted to bounce this off of some of the experts here. I’m new at diving into these sorts of tuning issues, but I’m looking forward to learning more and its fun.
Thanks for any input.
Is it possible that when my car was dyno tuned that the tuner turned off the rear O2 sensor input to the PCM?
Not the inputs, but the fault codes, the CEL and the SES warnings.
