Battery hold down clamp
Old May 31, 2013 | 09:28 PM
ironranger's Avatar
ironranger
Default Battery hold down clamp
Just purchased a 2001 convertible and the battery hold down clamp was out. I have the clamp and the bolt and purchased the spring nut that the Chevrolet dealer told me was standard per the parts list. The question I have is you can't get your hand under the battery tray to hold it while turning the bolt and I don't see how this would work going forward as whenever you would attempt to loosen the clamp to remove the battery it seems to me that the nut would just turn with the bolt. I would think that there should be a nut permanently attached to the battery tray to easily thread the bolt.
Did Chevy give me the wrong part or what am I missing?
Ironranger
Old May 31, 2013 | 10:30 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Yes, something is wrong there.
All you do is put the bolt through the hole in the plastic block and drop it into the battery tray hole and tighten it up.
Old May 31, 2013 | 11:05 PM
BigGun's Avatar
BigGun
Ironranger
Yes, there is supposed to be a nut attached to the tray.
Old Jun 1, 2013 | 04:33 AM
LoneStarFRC's Avatar
LoneStarFRC
The nut is attached to a plate which in turn, is pop-riveted to the tray.
Remove battery, remove battery tray (4 bolts), drill out old pop-rivets, install new nut-plate using 2 new pop-rivets, re-assemble.
Here's a couple good close-up views on ebay:
http://www.ebay.com/itm/1997-2004-C5-Corvette-battery-tray-LS1-LS6-NO-RESERVE-/290923246360?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bc607318&vxp=mtr#ht_101wt_1313
http://www.ebay.com/itm/1997-thru-2004-C5-Chevrolet-Corvette-Battery-Tray-Holder-Support-Z06-ZO6-1998-/330853125699?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d08620e43&vxp=mtr#ht_126wt_1075
HTH
Old Jun 1, 2013 | 09:16 AM
ironranger's Avatar
ironranger
Thank you! I thought there was supposed to be an attached nut-plate. The detailed parts diagram at the Chevy dealer didn't show that. Purhaps the easiest fix would be to purchase a new battery tray as they're not that expensive!
Old Jun 1, 2013 | 09:40 AM
ironranger's Avatar
ironranger
For such a simple problem, this is maddening. I just checked with the parts dept at a local Chevy dealer & was told there is NO nut-plate attached to the battery tray for a c5 corvette. The specs show a spring nut in which you need to reach under the tray a hold while tightening. This is not possible since you can't reach under the tray!
I could purhaps manufacture a nut-plate on the bottom of the tray, however, it shouldn't be that difficult an issue. Does anyone know "for sure" that a nut-plate is attached to the bottom of the factory battery trays?
Old Jun 1, 2013 | 09:46 AM
LoneStarFRC
.......... Does anyone know "for sure" that a nut-plate is attached to the bottom of the factory battery trays?
Did you look at the two examples I posted??? That's why I chose them due to the ability to actually see the nut and how it's attached.
CLICK on the pictures
Old Jun 1, 2013 | 10:18 AM
bumble-z's Avatar
bumble-z
LoneStarFRC, you couldn't have made it any simpler by posting up the pictures of the top & bottom side of the tray.
The picture clearly shows the two pop rivots holding the plate & nut in position, to keep the nut in it's proper place.
It also shows the clips in their proper placement to attach & re attach the tray to the proper place on the car.
Old Jun 1, 2013 | 04:32 PM
ironranger's Avatar
ironranger
Thanks LoneStarFRC! I ended up fixing the problem as you suggested. I removed the battery tray, punched out the two pop rivets and replaced the nut plate. My frustration was with the local Chevy dealer parts people who were no help at all as their parts diagram did not show a nut plate.
Old Feb 16, 2020 | 08:41 AM
sburger11's Avatar
sburger11
1st Gear
Default Battery held down enough
I just installed an optimal battery used the “puck”. It seems the back of the Battery is not held down. It’s held from the front of course. Is this normal?
Ironranger
Old Feb 16, 2020 | 10:06 AM
feeder82's Avatar
feeder82
the back of the battery is held by a ridge built into the tray, try loosening the hold down, push the battery towards the firewall and tighten it back down. It shouldn't move it all
Old Jun 21, 2023 | 04:22 PM
VetGirl's Avatar
VetGirl
4th Gear
Where do I buy the nut plate? I have 1997 and have the same issue you had.
To Battery hold down clamp
