Steering Column Lock
Old Jun 1, 2013 | 05:18 AM
realsmooth's Avatar
realsmooth
Default Steering Column Lock
I am getting an error message reading, "Steering Column Lock." Anyone know what this means and what the fix is? I have a 2001, C5, 6-speed. Any help would be appreciated. Thanks.
Old Jun 1, 2013 | 07:16 AM
red89c4's Avatar
red89c4
get a six pack and a cigar and read the below link.
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Jun 3, 2013 | 01:08 AM
realsmooth's Avatar
realsmooth
Default Replacing Battery
If I replace the battery, will I have to reset the warning indicator, so that the message stops appearing and goes out and if I do where is the reset located? Thanks.
Old Jun 3, 2013 | 07:56 PM
realsmooth's Avatar
realsmooth
I had the battery checked and it showed "low voltage." I installed a new Delco and so far so good. Thanks for all of the very useful information.
Old Jun 4, 2013 | 12:05 PM
tacman's Avatar
tacman
St. Jude Donor '13
Strongly suggest you search and install an LMC-5 to address future problems. It's been said that ALL C5's will have a column lock issue at some point in their lives.
Old Jun 6, 2013 | 01:27 AM
realsmooth's Avatar
realsmooth
Default Lmc5
OK, I just read the entire pages regarding the LMC5 module. I am going to order and install it before I have a problem or an emergency as the article suggests may happen. I read the following pages and will order from this company, unless someone has a better vendor that I should order from. I am not suggesting that I order from a 'cheaper' vendor, just a better vendor than the one on the following pages. I like the part where they state that the part is 100% American made.
http://www.complianceparts.com/index.html
Thanks again for all of the help. Being a newbie to being a Corvette owner, I am thankful for this forum.
Old Jun 14, 2013 | 02:13 PM
TEXHAWK0's Avatar
TEXHAWK0
After reading dozens of column lock posts over the years, I think I agree that most problems are because people don't drive the cars enough to keep the battery in good condition.
I installed the GM recall bypass relay almost 10 years ago, and have never had a problem.. I also suspect that having the lockplate removed, so that the locking pin does not get in a bind, also helps prevent problems.
To Steering Column Lock
