Where is Rear knock sensor?
Old Jun 24, 2002 | 10:08 AM
WOT99FRC's Avatar
WOT99FRC
Default Where is Rear knock sensor?
I have a DTC that translates to a Rear knock sensor. I looked all around and did not see any sensors, in the typical LT-1 area under the block. Does anyone know the location. Also, does anyone know if this DTC(PO332) will give check engine light after a certian number of detected knocks. I don't hear any knock and I always use AMOCO 93, so I am assuming the sensor is loose or Bad.
Thanks,
Luke
Old Jun 24, 2002 | 10:30 AM
WicketMike's Avatar
WicketMike
Cruising
Default Re: Where is Rear knock sensor? (WOT99FRC)
should be behind the manifold
Old Jun 24, 2002 | 10:37 AM
Bill Reid's Avatar
Bill Reid
Underneath the intake... and the wires exit the back of the motor.
Old Jun 24, 2002 | 05:52 PM
WOT99FRC's Avatar
WOT99FRC
Default Re: Where is Rear knock sensor? (billreid1@***.net)
Thanks, for the info.
To Where is Rear knock sensor?
