Grass Catcher...
Old Jun 5, 2013 | 12:04 AM
flynhi's Avatar
flynhi
Default Grass Catcher...
My radiator is partially blocked with grass cuttings from the highway mowers.
Any suggestions aside from garden hose, air pressure and medium bristle brush to clean it up? I have tried these with limited sucess.
Old Jun 5, 2013 | 12:08 AM
racebum's Avatar
racebum
pull the radiator and pick it out
you'll find a ton of crap lodged in there
if you still have your OE rad it may be more cost effective to replace it
new delco rads are only 180 shipped via amazon, part number is 20889
Old Jun 5, 2013 | 03:10 AM
striper's Avatar
striper
After you get it cleaned out you might want to put a screen covering the opening underneath. It will keep out an amazing amount of junk clogging up your radiator.
Old Jun 5, 2013 | 09:20 AM
CHJ In Virginia's Avatar
CHJ In Virginia
There is an easy way to clean out the AC condensor and the radiator. Order one of these compressed air tools. Extended nozzle with 90 deg turn on end.
http://www.rakuten.com/prod/mountain...212940104.html
Take off the top plastic radiator cover by removing 4 bolts. Hook tool up to compressor and blow the garbage out from the back. You will be amazed at the amount of junk you have to sweep up off the garage floor !! Be sure to do both radiator and AC condensor for beat results.
Old Jun 5, 2013 | 10:40 AM
flynhi's Avatar
flynhi
thanks to all for the tips.
Old Jun 5, 2013 | 11:25 AM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
You can also check out forum member Toque's procedure here with pictures.
http://www.toquez06.com/radiator.html
Old Jun 5, 2013 | 01:10 PM
gtmgooser's Avatar
gtmgooser
FLY - I just ran into this exact situation while in TN running the dragon. Rented a cabin for a week and once I got done running the Devils Triangle I found myself at about 240 degrees. I got concerned so I did a little maint right in the driveway of the cabin. Removed the air intake system, covered the throttle body with a ziplock bag and a hair tie, took off the "cap" covering the radiator, lifed the AC up out of its resting place which gave me enough space to use the pool table brush (low profile with soft brushes) to gently clear the grass, plastic wrappers and fur from the fins. I then connected my as seen on tv flex house and rinsed both units from behind. Made about a 40 degree temp difference and only took about an hour in all.
Old Jun 5, 2013 | 07:38 PM
kabluie's Avatar
kabluie
If you see the mower on the freeway, move over a couple of lanes to try to avoid the clippings. I realize that you can not do that on a two lane road.
Old Jun 6, 2013 | 09:57 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I did mine for the first time 2 weeks ago.
Car is 9 years old.
I used air with the tool above in my procedure.
I was SHOCKED how much grass and sand came out.
I should have taken a pic....
I could have filled a Gallon container with all the crap that came out.
Toque
Old Jun 6, 2013 | 09:58 AM
Toque's Avatar
Toque
Where do you get these ?
Toque
Old Jun 7, 2013 | 02:17 PM
2kbluestreak's Avatar
2kbluestreak
C5's catch grass in the back also. There's a 6 inch space between the rear valence panel and the outside of the hatchback "box." When I made my tail lights flush, I found quite a bit and cleaned it out. The only danger to having a bunch of dried out grass clippings and leaves there is it's being a source of fuel should any small fire develop, such as if a sheet of newspaper got sucked up and rested on a muffler.
Old Jun 8, 2013 | 02:01 AM
01Z0Sixx's Avatar
01Z0Sixx
Toque
http://store.corvetteforum.com/p-435...04-c5-z06.aspx
Here is the one I was eyeballing.
Or here's an easy to do DIY. Cheaper too.
http://forums.corvetteforum.com/c5-g...ng-screen.html
-Zach
Last edited by 01Z0Sixx; Jun 8, 2013 at 09:09 PM. Reason: Found a way cheaper one in the corvette store (new link)
Old Jun 9, 2013 | 02:45 AM
Toque's Avatar
Toque
-Zach
Zach:
Great thank u !
Toque
Old Jun 9, 2013 | 03:27 AM
01Z0Sixx's Avatar
01Z0Sixx
Zach:
Great thank u !
Toque
No problem
-Zach
To Grass Catcher...
