tb bypass coolant mod
Old Jun 24, 2002 | 11:54 PM
'99Hardtop's Avatar
'99Hardtop
Default tb bypass coolant mod
Guys, I did the throttle body bypass this past weekend and leaked some coolant on the garage floor. I drove the car today(1st time since I did the mod) and my check engine light is now on. It didn't seem to lose that much coolant. I was curious as to whether or not this has happened to anyone else. TIA, Robby.
Old Jun 25, 2002 | 01:02 AM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: tb bypass coolant mod ('99Hardtop)
Didnt happen to me on either of my cars. Did you check the fluid levels?
Old Jun 25, 2002 | 01:18 AM
4deatr's Avatar
4deatr
No problems with mine. Good luck
Old Jun 25, 2002 | 02:05 AM
SAXN8R's Avatar
SAXN8R
Low coolant should not set a check engine light. Pull the codes and post them so we can get to the bottom of it.
Here is a link on how to pull the codes:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jun 25, 2002 | 02:18 AM
SAXN8R's Avatar
SAXN8R
By the way, I will be away from the forum for a few days. So, by "we" I mean everyone else on the forum but "me"! LOL :jester
Someone should be able to look up the codes for you! Good luck!
Old Jun 25, 2002 | 07:35 AM
'99Hardtop's Avatar
'99Hardtop
Default Re: tb bypass coolant mod (SAXN8R)
Thanks for the help. I will pull the codes when I get home from work today and will post my results.
Old Jun 25, 2002 | 09:27 AM
RyanC7's Avatar
RyanC7
Anyone ever do a before and after dyno run to see if this even does anything?
:seeya
Old Jun 25, 2002 | 12:49 PM
Saleen351's Avatar
Saleen351
Default Re: tb bypass coolant mod (Ryan2002C5)
I can tell you that I did not feel any difference whatsoever so I just removed it and stored it away. If I see any hard data that it makes a difference I'll put it back on.
Old Jun 25, 2002 | 06:55 PM
'99Hardtop's Avatar
'99Hardtop
Guys, the codes my car showed were:
10PCM P1111 HC - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Votage -C, &
10PCM P0113 HC - Intake Air Temperature (IAT) Sensor Circuit High Voltage -B.
I guess there must be a Sensot that I unplugged unknowingly. Any info on what I am looking for?
Old Jun 25, 2002 | 07:12 PM
LovintheC5's Avatar
LovintheC5
I had those codes on mine, and it was the wires going to the Intake Air temp. sensor. Very easy, just cut and splice back together. The IAT is on the air bridge.
Daren
Old Jun 25, 2002 | 07:14 PM
'99Hardtop's Avatar
'99Hardtop
Default Re: tb bypass coolant mod (LovintheC5)
I will try that. Thanks Daren.
Old Jun 25, 2002 | 08:17 PM
'99Hardtop's Avatar
'99Hardtop
Problem seems to be solved. Thanks to all who provided their helpful insight. I have not actually driven the car again, but I did let it idle in the garage. No more codes. I will double check after I drive the car again. :D
Old Jun 25, 2002 | 09:01 PM
Jerryk's Avatar
Jerryk
Waste of time MOD. Had it did not like the look, put back the hose :rolleyes:
To tb bypass coolant mod
