A4 filler plug ?
Old Jun 24, 2002 | 11:54 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default A4 filler plug ?
does anyone have a picture of where it is ?
:eek:
Old Jun 25, 2002 | 12:09 AM
YELLOWDREAMZ's Avatar
YELLOWDREAMZ
Cruise-In II Veteran
Default Re: A4 filler plug ? (MRWHOOPPEE)
Drivers side of the pan facing the drivers side wheel. Near the back of the pan.
[Modified by YELLOWDREAMZ, 10:09 PM 6/24/2002]
Old Jun 25, 2002 | 12:15 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: A4 filler plug ? (YELLOWDREAMZ)
that is to fill the trans? I thought that was a drain plug. :confused:
Old Jun 25, 2002 | 01:23 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
TTT :cheers:
Old Jun 25, 2002 | 10:44 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
TTT :D
Old Jun 25, 2002 | 01:16 PM
carpe dm's Avatar
carpe dm
There is no "drain" plug; you have to lower the pan. What you see is the "fill" plug. :yesnod: :)
Old Jun 25, 2002 | 03:26 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: A4 filler plug ? (carpe dm)
Unfortunately to fill the tranny it is a cumbersome job. I perfered when you could just add oil thru the dipstick. You can change the oil via that hole with a suction device like I do and then add new oil back. The prefered method of adding oil requires the car to be running and on a level ground.
George
Old Jun 25, 2002 | 09:15 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: A4 filler plug ? (Speed-Racer)
that sucks :eek: :mad
To A4 filler plug ?
