Forgot to label 2 identical connectors.
Old Jun 12, 2013 | 06:58 PM
DooDooBear1999's Avatar
DooDooBear1999
Default Forgot to label 2 identical connectors.
Pulled my old LS1 intake today and forgot to label (like a moron) the 2 identical connectors that run behind the intake. One runs to the MAP sensor, the other runs to the sensor circled in red on the second photo. I am assuming the shorter one (circled in red in the first photo) runs to the MAP sensor since it feels stretched when connected to the sensor in picture 2. Don't want to start the car and find out they're swapped in a few days. Which is which? Thanks in advance.
[IMG][/IMG]
[IMG][/IMG]
Old Jun 12, 2013 | 08:13 PM
dblerman's Avatar
dblerman
Looking at pics from when I had my intake off, the gray one goes to MAP sensor and black one goes to cam position sensor.
Old Jun 12, 2013 | 08:15 PM
DooDooBear1999
Thanks for that. Can't believe I went full retard and didn't either note the color or label them when I disconnected them.
Old Jun 13, 2013 | 03:18 PM
dadaroo's Avatar
dadaroo
Another thing to remember is, the wire colors should be the same for the connectors. I don't think I have ever seen a wiring diagram where they change at a connector for the C5. I am quite certain that the wire colors would be different for each circuit/system. Not home now, but could validate with the FSM if you need it.
Old Jun 13, 2013 | 03:23 PM
DooDooBear1999
Shouldn't need that. I actually have the FSM here but didn't know that it had much about wiring in it. I found a picture from a thread earlier this year that shows the cam position sensor being black and I'm planning on matching wire colors up just to be sure when I go to put everything back together.
To Forgot to label 2 identical connectors.
