Long hesitation when starting
Old Jun 13, 2013 | 10:02 PM
danoz's Avatar
danoz
Default Long hesitation when starting
Symptoms since the new motor and blower was installed:
When the car is cold it turns over without hesitation.
If I stop and get gas or leave for 15 minutes it fires right up.
If I leave the car for 1 to 16 hours it takes almost 6-7 full seconds to turn over whether it is 32deg or 110deg outside.
I have had 3 very experienced/reputable tuners tweek the tune and test the suspect components(LPE box, PCM, Tune).
The LPE reluctor wheel converter box is fine and so is the PCM.
The car drives/behaves great from a stop to any speed at any RPM.
Has anyone had similar symptoms? If you did what was the issue?
I am running out of ideas. Thank you in advanced for reading this thread.
Thank you - Dan
Here is my set up.
GM LSX376 with LS3 Heads and intake
LPE Reluctor Wheel Conversion box
Blower Cam
Dynatech Headers
Procharger D1SC @12psi
8 rib Pulley Conversion
Twin Walbro Fuel Pumps
Precision 85lbs injectors
External Oil Cooler
RPS twin carbon lite clutch and alum flywheel
Old Jun 14, 2013 | 02:47 AM
CARRJET's Avatar
CARRJET
Do you mean you have slow rpm's while cranking it?
Old Jun 14, 2013 | 07:02 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
6-7 seconds to begin cranking? 6-7 secs to start up after cranking? If its the latter, get a fuel pressure gauge on there.
Old Jun 15, 2013 | 11:44 PM
danoz's Avatar
danoz
Once it turns over/starts it runs fine. It just takes a long time to crank/turn over.
Old Jun 15, 2013 | 11:45 PM
danoz's Avatar
danoz
It's the latter. 67psi of fuel pressure as soon as I turn the key. That was my first guess as well. It was behaving like it wasn't getting any fuel.
Old Jun 16, 2013 | 12:20 AM
Chicago1's Avatar
Chicago1
Mine does that sometimes also. Interested in what others say.
Old Jun 16, 2013 | 09:05 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
If it is "cranking" at normal speed, but not starting, your either not getting spark or fuel. Most likely is fuel. There is a check valve in the feed line near the tank that may be allowing the fuel to bleed back to the tank. Since you essentially have a one line system, if it bleeds back you will need to crank it until the air bleeds out of the injectors.
To check it, you can cycle the ignition a few times, then crank it. you can also release the shrader valve and have someone turn the key to the on position. If you get air out of the valve before fuel, it's bleeding back.
Be careful! Don't get fuel in your face or on a hot engine. Have rags handy to soak up what comes out. Let it dry before you crank it.
Old Jun 17, 2013 | 02:00 AM
danoz's Avatar
danoz
First of all, thank you for taking the time to respond. What you wrote makes sense but after my car sits for about a full day between start ups, the car turns over quickly without hesitation. Do you think that if it is bleeding back, during the process of losing FP in the lines the combination of air and gas could cause the hesitation where if the lines are completely empty it turns over quickly? Does anyone reading this have an after market fuel pump that allows the lines to bleed back to the fuel tank have a long hesitation when starting?
Old Jun 17, 2013 | 07:33 AM
Bill McCassey's Avatar
Bill McCassey
Like Marty said, cycle the ignition a few times. Turn the key to on but not start and let it sit there for about 5 seconds letting the fuel pump build pressure. do this 3-4 times then try to start it. If it starts right up , or starts much sooner then you have a fuel pressure issue.
Good luck
Old Jun 17, 2013 | 07:40 AM
helga203's Avatar
helga203
It might be your ingition switch. Check bill curle post on how to troble shoot switch. Just a thought.
Old Jun 17, 2013 | 08:33 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
For us to help you, you need to stop using the phrase "the car turns over". That phrase has to many interpretations. There are to basic no start conditions. The engine cranks normally but does not start or the engine does not crank. When everything is working, you turn the key to start and the engine begins to crank. Then the fuel injectors deliver fuel and the ignition fires the plugs. Generally after 1-3 seconds the engine comes to life or starts.
Old Jun 17, 2013 | 10:50 PM
danoz's Avatar
danoz
To clear up any confusion. When I turn the key the car cranks normally and starts within 1-2 seconds when the engine has not been running for over 12 hours.
After the engine has been running for any duration of time whether it is 10 seconds or 3 hours it does the following after the engine has been shut off.
Within about the first hour it cranks normally and starts within 1-2 seconds.
Sometime between 1-12 hours if you put the key in the ignition it cranks normally but the engine will not start for about 6-7 full seconds.
Old Jun 17, 2013 | 11:00 PM
danoz's Avatar
danoz
Good luck
Thank you for your response. I will have to try that when I get my car back. I have tried this few times but I only put the key in one time for about 5 seconds and noticed the Fuel Pressure was at 65psi(normal) and then turned it back to the off position and then tried to start it which still took several seconds. I will try it 3-4 times in a row next time and let you know the results when I get my car back.
Old Jun 18, 2013 | 02:47 PM
gun5l1ng3r's Avatar
gun5l1ng3r
I have a similar issue on my stock '04 Z and from what I gather, it is the check valve in the fuel line coming out of the tank...
Old Jun 18, 2013 | 03:39 PM
tlove32's Avatar
tlove32
I had a very, very similar issue...and I thought it was the battery. So I replaced it.....twice. Well - it turned out to be the cam position sensor. My tuner changed the version of the sensor, and it fires right up.
Old Jun 18, 2013 | 05:06 PM
mchicia1's Avatar
mchicia1
I am having the same issue after my forged 347 swap. Tried every parameter in hptuners, none make a difference.
Car sits, starts like crap. It will crank for 4-5 secs then start up. If you shut it off, and start again, it starts right up.
Interested in the solution!
Old Mar 31, 2014 | 09:27 PM
danoz's Avatar
danoz
I know it has been a while but I have finally found the cause of my problems. I had a twin pump setup in my car with a racetronix wiring kit. So there was a 10g wire that went to a 14g wire that fed two 12gauge wires(pumps). The connectors on both the inside and outside of the tank was damaged from excessive heat. After fixing this and replacing the 14 gauge wire with a 10 gauge wire in the basket the car starts up a lot faster. So in the end it was just a 25 cent part that cause all the issues for me. I am not in any way suggesting you remove your tank and check the connector because it was very expensive, just sharing the solution for my car.
To Long hesitation when starting
