Quick question hopefully easy fix
Old Jun 17, 2013 | 06:02 PM
Grizvette's Avatar
Grizvette
Default Quick question hopefully easy fix
Can't believe this one. Storm is coming in and wife went to park our 03 in garage and the ignition is locked keys won't even turn igniton. Only thing I can think of is she tried out truck keys first as they are fairly close in looks then I gave her the right ones.. But either set of keys will not work and the windows are rolled down. got to look for a tarp quickly. any ideas guys??????
Old Jun 17, 2013 | 07:51 PM
onlyavette's Avatar
onlyavette
Put the key in and turn it while you pull on the steering wheel to the left and right. It will require some force on the wheel so pull hard. I have had mine stick a couple of times because the wheel was turned when the ignition was turned off.
Hope that does it for you.
