running temp ?
Old Jun 24, 2013 | 05:42 PM
gmoXide26's Avatar
gmoXide26
Default running temp ?
on a 97 what temp should it run and what is considered hot?? mine gets hotter on the hwy then in traffic????
Old Jun 24, 2013 | 06:04 PM
racebum's Avatar
racebum
airflow through the rad is obstructed if that is the case
if you still have the oem radiator in a 97 it needs to be pulled and either replaced or very thoroughly cleaned. you will have a ton of crap in the AC condenser and rad. you will need a garden hose and air compressor
Old Jun 24, 2013 | 06:13 PM
gmoXide26's Avatar
gmoXide26
thanks ill have that done it gets up 2 220 is that hot?
Old Jun 24, 2013 | 07:49 PM
jcgunn's Avatar
jcgunn
Clean the crud out of the radiator--then expect (with stock thermostat) 190-192 on the hwy and 220 or so in the drive thru at Wendy's.
Old Jun 24, 2013 | 09:52 PM
kennedy759's Avatar
kennedy759
my 1997 runs 192
Old Jun 24, 2013 | 10:47 PM
gmoXide26's Avatar
gmoXide26
i have a new 160 themostat it runs 190 in traffic and 200 to 220 on hwy faster i go it gets 2 220
Old Jun 25, 2013 | 03:39 AM
Old Horsepower's Avatar
Old Horsepower
Have you jacked up front (using jack stands of course) and just looked up at radiator? It may just be part of a plastic bag or other debris/trash stuck up in there.
To running temp ?
