Mean Green............................I must be nuts !
I wasn't really happy with the location of my Line Lock. It was way too close to the headers. So........................... after removing the enire assembly, the alternator, and the washer resevoir :crazy: I found a place that suits me just fine. :D All I need to do is re-fabricate the lines.
Re: Mean Green............................I must be nuts ! (Mag Red Monster)
Cool, I'll probably be mounting my hurst line lock in a similar location.
It should be here tomorrow.
I think I found all the fittings i need commercially available, nothing custom, no cutting stock lines, I'll post all the details when I get it installed.
How did you keep the fluid from running down the frame and taking the paint off when you removed the line?
Re: Mean Green............................I must be nuts ! (66ImpalaLT1)
I just stuck a rag down there to catch the little fluid that runs out. Where in da hell did you find the fittings???? I had a devil of a time finding a 12mm
button flair fitting that goes into the portioning valve. What are you using??? Out with it! :D
I sat down with the manager at the local parts place and went through his catalog of adapters, he had one that should adapt the 12mm fitting to a normal 3/16 brake line. He had to special order them in, they werent even in his computer meaning they had never ordered them before :lol:. I'm hoping they'll be here tomorrow so I can say if they are correct or not.
Eric
I found some from Edelmann Brass (part #265000) and when I showed them to the guy that fabricated my lines he said they weren't right :confused: Not sure why..................................... .
Just went back into the garage and took another look........it appears that the Edelmann fitting is a 3/16 female end. If you are using hard line from the portioning valve to the solenoid...........it should work great. He apparently needed the adapter to have a male end to connect the the flex line. It's all so clear now. :yesnod:
Re: Mean Green............................I must be nuts ! (Mean Green 2000)
Hey guys.... heres a tip... I've installed several this way.. no problem.
The factory ends and lines are metric. However, the factory line size is just a tiny bit smaller than 3/16". What I did it take the metric ends and enlarge them a tiny bit to allow the 3/16 tubing to fit... This enlargement is only a very small amount, I did it with sandpaper. Then insert the tubing through the metric end, double flare the end, and you're done....
In the end, you have 3/16" line with a metric end on one end and an english end on the other (for the line lock)... works great. No adapters or welding or inventions required...
Re: Mean Green............................I must be nuts ! (nevrenuf)
Just an idea.
:eek: OK Tom .............. where were you a week ago when Mean Green and I were posting like crazy about how to install this damned thing? :p: :jester
Actually he posted this a while ago. I read it when I was searching old posts. I'm going to try the adapters first, so I can keep the stock line around in case something goes horribly wrong. :)
