2000 Running Rich
Old Jun 25, 2013 | 02:53 PM
2000tred's Avatar
2000tred
Cruising
Default 2000 Running Rich
My vette has recently started running rich. Over the past few months its fuel consumption has steadily gone up. At times when its cold it has a little black some coming out of the exhaust and smells rich, which would indicate a rich condition. I took it out for a drive a few nights ago and it was at 200 degrees (coolant temp). I accelerated it a little hard, and it had a cloud of smoke come out of the exhaust. I could notice it easily with it being night and illuminated by the driver behind me.
Old Jun 25, 2013 | 03:56 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
A vacuum leak between your MAF and intake manifold has been known to cause bad MPG. (un-metered air)
Same with any of the various vacuum lines going into the intake manifold.
I'm no pro on which one causes what. Hopefully a pro will chime in.
Toque
Old Jun 25, 2013 | 04:07 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
check all your hoses for a vacuum leak.
Old Jun 25, 2013 | 04:17 PM
3boystoys's Avatar
3boystoys
Unmetered air causes LEAN conditions not RICH.
Old Jun 25, 2013 | 04:40 PM
printmanjackson
the o2's see the additional air and add fuel
Old Jun 25, 2013 | 06:52 PM
2000tred's Avatar
2000tred
Cruising
I have checked the vacuum lines and they appear to be in good shape. The throttle body tube from the MAF is tightly secured and has no cracks.
Old Jun 26, 2013 | 07:19 AM
baxsom's Avatar
baxsom
are you getting any DIC codes?
Old Jun 26, 2013 | 02:16 PM
2000tred's Avatar
2000tred
Cruising
It has no codes or service engine light.
Old Jun 26, 2013 | 02:42 PM
3boystoys's Avatar
3boystoys
Not when it's unmetered AFTER the MAF, that's the point. The MAF reports what it thinks entered the engine but more air has entered (i.e. a LEAN CONDITION).
The thing to CHECK it the O2 sensors, as they age they get "lazy" and do not respond quickly causing poor fuel consumption. Just caught the O2's on my truck last night with my laptop, one was not responding at all and the other was barely moving. Off to but some new ones today.
Old Jun 26, 2013 | 03:03 PM
2000tred's Avatar
2000tred
Cruising
Ok. I have a friend that has a Mac scanner capable of graphing the sensors out puts. I will go first thing in the morning and take a look at the O2 sensors operation. I will post back what I find. Is there anything else I should look at while I have the scanner hooked up?
Old Jun 26, 2013 | 03:49 PM
3boystoys's Avatar
3boystoys
Long and short fuel trims.
Old Jun 26, 2013 | 06:31 PM
RedZMonte's Avatar
RedZMonte
Old plugs? slow O2's? Sticky Injector? Dirty Maf? scanner will tell you what its seeing.. a vac leak that large should pop a P0171 lean code.. check pending/history codes. LTFT's and STFT's like mentioned above will tell you more. might want to try some FI cleaner.. I have had great luck with BG44K, and some MAF cleaner.
S
Old Jun 26, 2013 | 07:05 PM
2000tred's Avatar
2000tred
Cruising
About 2 weeks ago I ran a strong solution of sea foam directly to the injectors using the fuel pressure test port. It didn't help out any. It had good fuel pressure that was in specification.
Old Jun 26, 2013 | 07:31 PM
gun5l1ng3r's Avatar
gun5l1ng3r
A leaky injector can't be fixed with a Seafoam solution. A leaky injector stays 'open' longer than the computer specifies and as a result, you leak extra fuel into the cylinder.
They can also leak while the car is off. You might want to pull some plugs and see if any are discolored or 'wet' from the extra fuel...
Old Jun 26, 2013 | 08:51 PM
2000tred's Avatar
2000tred
Cruising
If an injector was leaking wouldn't the fuel rail loose pressure after the engine is shut off? I put a fuel pressure gauge on it and left it on the rail for ten minutes after I shut it off and it held good pressure.
Old Jun 26, 2013 | 10:17 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
If you have the time, the following is a good tutorial on how they function and adjust themselves as needed.
Old Jun 28, 2013 | 01:19 PM
2000tred's Avatar
2000tred
Cruising
I hooked up the scanner to the car yesterday and from what I found I believe it's a bad o2 sensor. The bank 2 sensor 2 was mainly staying around 65-80 mv. The bank 1 sensor 2 was fluctuating good between 70mv to aroun 180mv. At idle. When I accelerated the car all the sensors fluctuated alot except for the bank 2 sensor 2. How can 1 o2 sensor drive it as rich as it is? I checked the Maf and other sensors while I had it on the scanner and they were in specification.
To 2000 Running Rich
Old Jun 28, 2013 | 02:03 PM
3boystoys's Avatar
3boystoys
Yep, and I bet the long term fuel trim was way in Negative territory. That's why you mileage stunk. My Truck did this the other day and same issue, My LTFT numbers were buried in Negative territory.
You should change BOTH front sensors while your there, they are maintenance items just like spark plugs, the front O2's are used for fuel adjustments, the rears are used for determining Catalyst efficiency so the front ones are the IMPORTANT ones.
You may have to disconnect the negative battery cable to get the Long Term settings to reset.
Old Jul 1, 2013 | 11:32 PM
2000tred's Avatar
2000tred
Cruising
I installed new o2 sensors and my fuel mileage has greatly improved. Thanks to everyone for your help and suggestions. Is there anything anyone recommends to put in to keep them clean?
Old Jul 2, 2013 | 07:00 AM
dart.deanda's Avatar
dart.deanda
Good gasoline! Glad to see a problem resolved on one of these cars... congrats.
