which header bolt?
Old Jun 25, 2013 | 06:35 PM
Tar Heel's Avatar
Tar Heel
Default which header bolt?
ARH 1 & 7/8" race headers and off-road x-pipe arrived today. I was planning on installing them this evening and tomorrow but there are no header bolts in the package. The instructions recommend reusing the OEM bolts. I didn't save them (my fault) on teardown as I assumed that with a set of $1700 headers would come new, better bolts too.
Which header bolts do you recommend? I'd like to call Summit tonight and get them ordered to have them here by Thursday or Friday.
Thanks.
Scott
Old Jun 25, 2013 | 06:59 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
get the ARP studs
Old Jun 25, 2013 | 07:02 PM
zeevette's Avatar
zeevette
Without a doubt, get the ARP studs and fasteners. When I stripped out a header bolt-hole, I installed the studs in the repaired heads. I've since had the headers loose/off about 3 times, so they really paid off in convenience. Aluminum heads are surprisingly easy to strip with steel bolts. They are 12pt. fasteners, so have the proper tools handy.
Old Jun 25, 2013 | 07:17 PM
thepitstop2010's Avatar
thepitstop2010
Originally Posted by printmanjackson
get the ARP studs
Old Jun 25, 2013 | 09:20 PM
Tar Heel's Avatar
Tar Heel
Thank you gentlemen. I ordered a set from Texas Speed. Should be here Thursday. Does anyone know about some on the driver's side studs that can't be installed until the header is up and on? Again, they are ARH 1 & 7/8".
Old Jun 25, 2013 | 11:18 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I've installed well over 200 sets
OEM bolts 100%, all the other options are just internet hype
Old Jun 26, 2013 | 07:10 AM
LoneStarFRC's Avatar
LoneStarFRC
For the most part a solution in search of a problem.
Old Jun 26, 2013 | 07:33 AM
printmanjackson
he said he threw them away in that case I would purchase ARP studs.
Old Jun 26, 2013 | 07:54 AM
LoneStarFRC
GM 11518860
Old Jun 26, 2013 | 09:04 AM
bumble-z's Avatar
bumble-z
I agree.
I've had my original GM header bolts on my LG Pro's for around 9-10 years now & they haven't loosened up & are still tight.
Old Jun 26, 2013 | 07:43 PM
zeevette's Avatar
zeevette
You're just being cheap. If you ever have to drop your headers, the studs pay for themselves in convenience. I don't have a lift, so all my mods have been done on stands. My opinion might change if I had a shop. Not on my car.
Old Jun 26, 2013 | 10:03 PM
SteveDoten's Avatar
SteveDoten
And I'd buy OEM GM bolts
All the Best.
Steve
Old Jun 26, 2013 | 10:45 PM
Ohyoufan's Avatar
Ohyoufan
I bought some black bolts from a vendor on eBay for both my old ws6 and c5 and have dropped the headers multiple times on both cars and they've been fine
Old Jun 27, 2013 | 06:56 PM
Russ K's Avatar
Russ K
I reuse the oem bolts, but use an 8mm lock washer, as the bolts are close to bottoming out in the cylinder heads due to the thinner header flanges vs the stock manifolds.
Russ Kemp
Old Jun 29, 2013 | 02:00 PM
Tar Heel's Avatar
Tar Heel
Thanks everyone for the advice. I went ahead and purchased a set of the polished stainless ARP studs and couldn't be happier. Made installation (by myself) quick and easy. I would buy them again! Appreciate all the help.
To which header bolt?
