dba/stoptech/hawk/motul/rotors/pads/fluids
$575.95 delivered lower US
http://www.xplosiveperformance.com/9...ds_p_3524.html
97-04 Corvette C5 Front Slotted 4000 Series Rotor Right & Left Pair
$316.84
http://www.xplosiveperformance.com/9...ir_p_2999.html
1997-2004 Corvette C5 Stop Tech Gas Slotted Front & Rear Rotors w/Hawk HP Plus Brake pads
Package Includes
(1) Right Front Gas Slotted Rotor
(1) Left Front Gas Slotted Rotor
(1) Right Rear Gas Slotted Rotor
(1) Left Rear Gas Slotted Rotor
(1) Set Front Brake Pads (4 pieces)
(1) Set Rear Brake Pads (4 pieces
$593.97 delivered lower US
http://www.xplosiveperformance.com/1...ds_p_2901.html
97-04 Corvette C5 ZO6 HPDE Starter Track Pack Brake Package
(1) Set (4 Lines) Goodridge Corvette C5 Stainless Steel Brake Line Kit
(1) Set Hawk HP Plus Street Front Brake Pads 1 pcs design
(3) Pints Motul RB600 High Temp Race Brake Fluid
(2) StopTech Front Gas Drilled Rotors
$564.35 delivered lower US
http://www.xplosiveperformance.com/9...e-_p_3500.html
Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C).
500ml bottles
1.05 pint
$17.95 each
http://www.xplosiveperformance.com/M...00-_p_648.html
$316.84
Package Includes
500ml bottles
1.05 pint
$17.95 each
$316.84
Package Includes
500ml bottles
1.05 pint
$17.95 each
$316.84
Package Includes
500ml bottles
1.05 pint
$17.95 each
$316.84
Package Includes
500ml bottles
1.05 pint
$17.95 each
