It is HOT and I need HELP!!!
Old Jun 26, 2002 | 09:50 AM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Default It is HOT and I need HELP!!!
My A/C is cold and my blower is pushing hard but very little is coming out the vents. :mad I can switch to defrost, vent & back and forth and nothing much comes out. Anyone having had this problem -- what are the possible solutions. Thanks in advance.
Old Jun 26, 2002 | 10:34 AM
wwashing's Avatar
wwashing
Default Re: It is HOT and I need HELP!!! (Mad_Dog)
This may be a stupid question, but did you turn up the fan speed?
Old Jun 26, 2002 | 11:20 AM
COOL Z06's Avatar
COOL Z06
Did you check your vacuum line connections?
If you were under the hood (tinkering/cleaning) or under the dash you might have knocked a line loose.
Just a thought! :D
Old Jun 26, 2002 | 11:26 AM
MelloYellow's Avatar
MelloYellow
Default Re: It is HOT and I need HELP!!! (COOL COUPE)
Play with the 'Mode' button.
Old Jun 26, 2002 | 12:41 PM
Stu in CA's Avatar
Stu in CA
Default Re: It is HOT and I need HELP!!! (MelloYellow)
Yea, I played with the "Mode Button" and watching that computer try to out guess me and tell me what I want...made me hotter! jk
Check those hoses! I had the same problem and spent some time searching last night with fuel-rail covers off and Bingo! Unconnected vacuum hose, problem solved. Plus, I noticed that the worthless dealer had failed to tighten the two rearmost intake bolts, they were not even started in the threads! :mad
Old Jun 26, 2002 | 01:49 PM
NXVette's Avatar
NXVette
Sorry to hear about that, but I had the same problem last monh, and it cost me $531.00 at the dealer ship, because the pipes were leaking in several diff. places. Good luck.
To It is HOT and I need HELP!!!
