Electrical Problem
Old Jul 6, 2013 | 05:28 PM
mr65vet's Avatar
mr65vet
Cruising
Default Electrical Problem
All at the same time; both DRL's, both turn directions, interior lights, and FOB stopped. Checked grounds and fuses, all O.K. In reading the schematic, the only common item is the BCM. How can I check the BCM with out replacing it (come to think of it, my wife has a 1998 coupe and mine is a 2001 conv), has anyone had this problem, and if so, what was the problem?
Old Jul 7, 2013 | 04:01 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like a fuse. I can't remember if it's #4 or #6 in the passenger foot well compartment. But I would stat there.
Also do you have any codes ?
Old Jul 7, 2013 | 11:14 AM
mr65vet's Avatar
mr65vet
Cruising
Default Electrical problems
8vette7,
Thanks for the reply. Nice info on BCM differences. I don't think it is the stalk because my tail lights work just fine, abet fast. The carpet is dry on the passengers side, but the BCM could still be out. The left and right side signals enter the BCM on two different connectors. And the headlights function correctly and the side markers light up. I am stumped.
mr65vet
Old Jul 7, 2013 | 01:15 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by mr65vet
8vette7,
mr65vet
If your tail lights are fast you might have a bulb or short issue. There is not enough resistance that is why the turn signals are flashing faster than they should be.
To Electrical Problem
