Vararam and air temperature
Old Jul 7, 2013 | 07:02 PM
bobby777's Avatar
bobby777
Default Vararam and air temperature
With the scoops in front of the car--I would think the air entering the intake and into the engine is the same temp as outside air? Compared to the stock unit and many others that let hot underhood air in--
Old Jul 7, 2013 | 07:27 PM
onlyavette's Avatar
onlyavette
Sounds reasonable to me.
Old Jul 7, 2013 | 07:34 PM
momo20's Avatar
momo20
yes that is the point of a cold air intake.the open air filters that just sit in the bay those do nothing but collect hot air..the honker .vararam and ones that are by design are meant to collect air out side the car and that is where you get your performance from!
Old Jul 7, 2013 | 09:28 PM
Patches's Avatar
Patches
When I first installed my Vararam years ago, I conducted a test and measured the intake air temp before and after installing the Vararam. The air temps before were 30-40 deg. F higher than ambient. With the Vararam, they intake air temps never exceeded ambient.
Old Jul 7, 2013 | 11:18 PM
bobby777's Avatar
bobby777
THX. Was that with the OEM air cleaner/filter? 30-40 higher temp going into the motor robs H/P--that's like racing in 60 deg. weather on the same track and than going back and its 90-100 degrees--we all know which day you would run more MPH=BTW--what would the temp go to when idling at a stop light 2-3 minutes--on hot calf day with the VAR?
Old Jul 7, 2013 | 11:46 PM
lionelhutz's Avatar
lionelhutz
Stopped or moving slowly the Vararam will heat soak quite badly. On a few hot days when I was logging it was high 90's out and the IAT sensor was showing 140* plus.
Old Jul 7, 2013 | 11:51 PM
onlyavette's Avatar
onlyavette
As with any other brand or type of aftermarket or stock.
I think the v-ram will cool down quicker than most others will though. Sadly though, I have to say "I think" because I have know data to back that statement up.
Old Jul 8, 2013 | 03:03 AM
RonSSNova's Avatar
RonSSNova
Well, is it worse or the same as stock?
Where is the IAT sensor?
It's going to depend on the year of the car. I would assume things change with the later MAF with the sensor built in. And the location of the sensor.
On my setup, the MAF (later one) sits in front of the radiator above the plastic. I loged many 90 degree day crawls through ttraffic and didn't see more than 10 or so above ambient. Anytime moving, it's right at ambient.
Good product.
Ron
Old Jul 8, 2013 | 09:53 AM
lionelhutz's Avatar
lionelhutz
Ron
No idea, I never had a stock intake.
To Vararam and air temperature
