trans issue
Old Jul 7, 2013 | 08:33 PM
chevy2's Avatar
chevy2
Navigator
Default trans issue
looking for knowledge....... 2003 convert. seems to have tcc lock up stumble at 50 to 60 mph under light throttle . does anyone know of a fix for this??
Old Jul 8, 2013 | 09:35 PM
momo20's Avatar
momo20
what is tcc ?
Old Jul 8, 2013 | 10:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
There are 2 things that will cycle the TCC from lock/unlock
1st if there is a foul in the brake light circuit or you touch the brake pedal---it will unlock the TCC
2nd If you have any misfire--either real or false--it will unlock the TCC
Sounds like you have a misfire--because you say it stumbles- and when the TCC is locking is when the engine is under a large load for P/T-and where a P/T misfire is most likely to occur
Old Jul 8, 2013 | 11:09 PM
thumpinc5's Avatar
thumpinc5
Are you feeling a "shudder"? A shudder is usually caused when the clutch material is starting to burn up or the piston has a slight crack.
Frank
To trans issue
