Help replaced ebcm
Old Jul 11, 2013 | 06:50 PM
Wahoo12's Avatar
Wahoo12
Default Help replaced ebcm
For 2 month i have checked grounds,plug ends,fuses etc. Could not find the issue that caused codes P1571,C1277 & U1040.
I purchase a rebuilt ABS,installed rebuilt unit and drove about 10 miles. No lights on dash. Turned the car off,then restarted DIC said service engine,service active handling system.
The codes now have a H at the end,
P1571H
C1277H
U1040H.
Is there something else that I missed.
Thanks.
Old Jul 11, 2013 | 07:56 PM
Greg_E's Avatar
Greg_E
The H means it is a history code.
Try clearing them and try it again.
Old Jul 11, 2013 | 11:19 PM
Wahoo12's Avatar
Wahoo12
Default replaced ebcm
Just returned from reconnecting the battery.Car started.No codes. Restarted car. No codes.
I will test again in the morning.
Thanks to all.
Im so glad I joined Corvette Form. Keep sharing the knowledge.
Wayne
Old Jul 12, 2013 | 12:38 AM
Wahoo12's Avatar
Wahoo12
Before I replaced the ebcm the codes would set with starting the car.
I will drive and as always ck codes with engine running. These codes have never lit the DIC or dash icons while driving.Only after stopping and restarting engine.
I just hope this cures the problem. A lot of threads on this subject.
The vendor would like my core within a few weeks. If repairable the core charge will be refunded.
After all the threads,C1277 is not repairable. I might just keep it. Hang it on the wall.
Take care, will let you know the outcome.
Old Jul 12, 2013 | 10:11 AM
Wahoo12's Avatar
Wahoo12
Went for a drive this morning. Started car every thing fine.Stopped for fuel,started car and Dic and dash lights up. Same as before.
Returned home and with car still running ck codes.Same codes.
P1571H
C1277H
U1040H
There is one code BO432CH. Rear defogger relay circuit. I don't believe this has any thing to do with my issue.
Any ideas? About ready to sell the car.
thanks,
Wayne
Old Jul 12, 2013 | 11:15 AM
Wahoo12's Avatar
Wahoo12
8VETTE7
ck fuses ok.
I have heard of people with the same codes cleaning their ing switch to clear codes.
Should I try this? A manual would not help me. Never used a meter before. Hard time with elect.
To Help replaced ebcm
