Jammed headlight
Old Jul 14, 2013 | 10:07 AM
1ST-C5's Avatar
1ST-C5
Default Jammed headlight
One side functions properly. The other stays down unless i turn off the ign and give the manual screw a few turns up or down. I restart and then she goes up. I have to adj the screw every time i start the car to get it up. Any ideas?
Old Jul 14, 2013 | 10:11 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
ideas?? yeah its Fd up
try flipping the beige stops over....sometimes they get an indention in them and the light travels down farther than normal and won't pop back up....otherwise sounds like you have the start of a bad gear issue..
Old Jul 14, 2013 | 11:04 AM
pewter99's Avatar
pewter99
Originally Posted by 8VETTE7
Sounds like a bad spot (teeth worn/gone) on the plastic gears. Worth trying the "turn the bump stops 180 degrees" thing, but I wouldn't expect it to cure the problem.
and to go one step farther if you are gonna order the gear..get both
Old Jul 14, 2013 | 12:25 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
also get the brass gears not the plastic ones.
Old Jul 14, 2013 | 05:45 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Solution::
I had ordered my replacement gear from Ecklers. They sent me the wrong version 3 times and have yet to refund me for one of them despite nearly a dozen customer contacts. Don't use them.
You can order the gears here: Rodney Dickman
Taking the headlight assembly out to replace the gear is pretty easy. You need a Philips screwdriver, a T15 or so torx, and iirc an 8mm socket or small wrench along with a 10mm for the motor itself.
Replacing the gears in the motors is dead simple and took just a few minutes. Removing and reinstalling the headlights takes about 10 minutes if you've done it before, or maybe 25 each taking your time.
If you're in there, it's a good opportunity to replace your bulbs.
Old Jul 14, 2013 | 07:10 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Originally Posted by Tusc
Solution::
Thanks!! I was about to order from Ecklers. My gears where making that awful noise when I close the headlights. I have the older headlight motors (98) so I don't have to do the "glue" method.
Old Jul 15, 2013 | 12:22 AM
Tusc's Avatar
Tusc
I found that I was quite happy to have my 99 for the exact same reason. Simply replace the gears and spin the screws down in order. No wait, no mess. Just toss them back in the car and away you go.
Old Jul 15, 2013 | 10:04 AM
lionelhutz's Avatar
lionelhutz
Try taking the arm off the motor, rotating the motor 180* with the **** and then putting it back together. It will likely work for a while anyways.
Old Jul 15, 2013 | 04:01 PM
Tusc's Avatar
Tusc
That would be a LOT of work to hope that a jury rig might work. If the gear is stripped, rotating the motor will help nothing when the stripped section gets back to the screw and it stops again.
Old Jul 15, 2013 | 04:08 PM
lionelhutz's Avatar
lionelhutz
It should take you about 15 minutes to do. That's how I tested mine, it worked for the rest of the summer before I changed the gear over the winter and I have a Canadian car that automatically turns the lights on any time the sun isn't out.
To Jammed headlight
