AC question
Old Jul 14, 2013 | 10:51 AM
cvette99's Avatar
cvette99
7th Gear
Default AC question
Year: 1999, A/C: manual
Problem: A/C not blowing cold
I vacuumed (had negative pressure for 24 hrs), added dye and recharged the system. The system blew cold for about a week (no compressor noise). I checked for leaks and found traces of dye under the compressor and on it.
Question: If the compressor had a leak could a negative pressure be maintained??
If I change the compressor,orifice and dryer should I flush the entire system??
Thanks for any help
Old Jul 14, 2013 | 12:53 PM
kg54trains's Avatar
kg54trains
Thanks for any help
There is a great thread on a A/C repair that gives you detailed infor with pics about the work involved, tools needed, advise on a step by step progression...Any work on the A/C system replacement should have a system flush and a system vacuum before you start to replace parts, add r134, or the compressor/refrig lub-oil-PAG#..Look up the thread it is a Winner
Old Jul 14, 2013 | 01:23 PM
cvette99's Avatar
cvette99
7th Gear
I read that article and it is great. My main question is could I have a compressor leak and still be able to maintain a negative vacuum??
Old Jul 14, 2013 | 01:32 PM
corvettebob1's Avatar
corvettebob1
Sure you can still have a leak, your only holding 30hg of vacuum.
If your finding traces of oil around the compressor or oil pan more then likely that is your leak.
To AC question
