need help finding an interior part retaining clip
Old Jul 16, 2013 | 05:35 PM
janky's Avatar
janky
Default need help finding an interior part retaining clip
I had to remove the knee bolster panel under the steering wheel yesterday, and when I did the metal retaining clip that holds in the trunk release latch popped off and is now MIA. Sorry, I don't have an actual picture of the clip, but it's a small metal retainer clip that slides onto a plastic tongue of the switch assembly which holds it in the knee bolster. A new trunk latch switch is almost $200 according to the local dealerships!
http://www.vettenuts.net/index.php?l...t_detail&p=327
Part 20 on this diagram, again just need a retainer clip for it not the whole part (the switch part# is 12135157 if that helps)...
Old Jul 16, 2013 | 05:58 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
That part probably uses the same clip that's used for many interior panels. I'd see if a dealer could locate the clip separate on one of the rear side panels. I'll take a look in the garage but I don't think I have my original switch anymore to yank the clip off for ya. Another option would be a local swap meet at a car show. Lots of used stuff there and reasonable prices including interior clips, screws etc.
Old Jul 16, 2013 | 10:13 PM
LoneStarFRC's Avatar
LoneStarFRC
I think Z06uf is right. That same retaining clip is likely used on a number of other interior panels and may also be used on other GM vehicles, not just Corvettes.
The green metal clip in the pic is what you need right?
I think the traction control panel also uses that same clip, probably others as well like the knee bolster panels, etc.
Salvage yard or even the body shop at a GM (not just Chev) dealer would have extras.
Old Jul 16, 2013 | 10:46 PM
janky's Avatar
janky
excellent suggestions guys, thanks! I've got the situation under control for the moment with a wad of masking tape carefully shaped to do the job, but obviously that's not permanent. I will try taking off the panel this weekend to search for the MIA clip again, otherwise I'll hunt down some sort of replacement with your suggestions.
Old Jul 17, 2013 | 09:40 AM
NealB's Avatar
NealB
myself and a bunch of Z06 owners replaced the trunk pop switch with a fog light/trunk pop switch when adding fog lites
I'll look to see if I have the original switch and if so can send it to you (I'm out of town and not able to look for several days)
in the meantime, post in the Z06 section asking if someone else has theirs
Old Jul 17, 2013 | 06:03 PM
Z06ufgrad2002
My original switch is gone. Sorry I couldn't help you.
To need help finding an interior part retaining clip
