Anyone running base C6 rims?
Old Jul 17, 2013 | 03:07 PM
Turbooo2u's Avatar
Turbooo2u
Default Anyone running base C6 rims?
A friend of mine just pulled off his stock rims of a base 2013 coupe and only wants $250 for them. I know they are an inch larger in diameter. 18/19". Will these fit and work properly on my 01' vert'?
Old Jul 17, 2013 | 03:54 PM
3boystoys's Avatar
3boystoys
The base wheels aren't very attractive.
Old Jul 17, 2013 | 04:50 PM
Turbooo2u's Avatar
Turbooo2u
True, but for $250, and they look a little better than what I have now. But from the above post, it could be problematic.
Old Jul 17, 2013 | 06:30 PM
TastyBacon's Avatar
TastyBacon
I have base C6 wheels on my '99 coupe. I am running a 5/16" spacer in the back, and no spacer up front. They aren't pushed out quite as far in the wheel wells as some might like, but they don't rub and they don't pelt the rear fenders with rocks like a "flush" offset would. I think they look great, and really update the look of the car.
Old Jul 17, 2013 | 08:14 PM
NOMOREWORK's Avatar
NOMOREWORK
St. Jude Donor '13-'14-'15
I have C 6 wheels on my 98 Coupe. Use a 1/4 inch spacer on the rear and you will be fine.
Old Jul 17, 2013 | 09:15 PM
ndirishr1's Avatar
ndirishr1
I bought a set a friend pulled off his C6 with good stock tires with a plan to use them as winter wheels. Bought a set of sensors and installed. Fronts worked great, rear just brushed the back of the wheel housing. Had to buy spacers. Used them 1 season on my 2001. Sheared a lug off the rear and had to have it replaced on the road. Expensive job on a C5. Took the wheels off and sold them. DON'T DO IT MAN!!!!
Old Jul 18, 2013 | 07:24 AM
3boystoys's Avatar
3boystoys
Spacers are a bad idea for this and bearing load too. Stay away from them.
Old Jul 18, 2013 | 09:12 AM
1sickz51vette's Avatar
1sickz51vette
I find the C6 base wheels in chrome really update the C5 look, hell even black or silver is an upgrade.
Old Jul 18, 2013 | 10:38 AM
Ogopogo's Avatar
Ogopogo
If you are going to use a spacer make sure it is a hub centric adapter/spacer and not just a flat plate with holes in it. The wheels are hub centric.
PM me if you want the name of a source which builds custom adapter/spacers. Very pleased with their product.
To Anyone running base C6 rims?
