Powershifting?
Old Jun 27, 2002 | 06:13 PM
Stingray1967's Avatar
Stingray1967
Default Powershifting?
Ok. Stupid question.
What is powershifting?
I've never owned a manual tranny car. Is it where you don't step in the clutch to shift? :confused:
Old Jun 27, 2002 | 06:21 PM
MeatheadsC5's Avatar
MeatheadsC5
Default Re: Powershifting? (Stingray1967)
Mashing the throttle to the floor, and leaving there when you shift the gears moving the clutch as fast as possible. If you do it smooth enough, it will feel like a stiff automatic transmission.
Old Jun 27, 2002 | 06:46 PM
RT66Z06's Avatar
RT66Z06
Powershifting is a rush!
But, unless you've got lots of money and a scatter shield around the clutch housing, don't do it - at least not with your own car! A number of years ago, as a transmission development engineer, I personally destroyed a couple of Cobra Jet Mustangs perfecting kicking the clutch and mashing the next gear at the car's red line. I got pretty good at it and it was a blast -but I shy away from doing it on my baby!
Btw, there is only one speed for each gear when the output shaft and the input shaft (the engine) are running at the same rpm to allow clutchless shifting. There were some radical transmissions built for drag racing.
Enjoy!
Old Jun 27, 2002 | 07:18 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: Powershifting? (GR8C5)
Yes...keeping the gas down while shifting...
Old Jun 27, 2002 | 11:08 PM
Stingray1967
Default Re: Powershifting? (2000^C5)
:eek::eek::eek::eek::eek::eek::eek::eek: :eek::eek:
Ok, thanks guys.
Old Jun 28, 2002 | 02:25 AM
BigBlue's Avatar
BigBlue
It ain't that hard on the tranny. :rolleyes: Got a buddy who does it all the time in his stang.
Old Jun 28, 2002 | 04:15 AM
Snowwolfe's Avatar
Snowwolfe
Default Re: Powershifting? (BigBlue)
I said this before and will say it again. GM guidelines are that all corvette transmissions are tested with 600 full power shifting from first to sixth gear before they are approved for installing in the cars. GM themselves power shift when testing there cars for et's and 0-60 times. Sure, Like everything else it can be bad but everything in moderation:))) Enjoy. Its a blast to power shift second gear and go side ways. It brings out the kid in me and its warranted for 36/36
To Powershifting?
