DTC 1232 RF Wheel Speed Sensor
Old Jul 18, 2013 | 03:34 PM
Race Prepared's Avatar
Race Prepared
Default DTC 1232 RF Wheel Speed Sensor
Recently experienced DTC 1232, right front wheel speed sensor. Took ohm measurement at 1086 (within tolerance) and .9 mvolt upon rotating the wheel as fast as possible with car on jack. (Also seems within tolerance). To insure my garage testing was accurate, I performed the same tests to the LF wheel speed sensor and obtained the same result. Since the sensor appears to be good, would the brake module be defective & is it repairable?
Corvette experiencing the problem: 2003 Z06
