I have one installed in my C5 and it is absolutely great.
I saw that IM not crazy that it is a remote control I would prefer having a hardwired switch and mounting it in the ash-tray or something but I guess if that is one of the only options I will seriously consider it...
I just want it for when I am at the track in the staging lanes
This product works great and the installation is simple and fast (it only takes a few minutes). As far as the remote (it comes with 2 fob's) just do what I did, attach a piece of Velcro to the back of the remote and attach it to your dash board. The other remote is a spare and I keep it in the glove compartment.
If you want to do this modification I would listen to 8VETTE7 (Chuck). He is the Forum guru on the C5 fans and operation design, not to mention many other aspects of the car.
A double pole, single throw toggle switch will allow high speed fans to be selected. Hook to the DK GRN and DK BLU wires from the PCM and use one pole for each wire. Connect the other 2 terminals to ground.
You could also get fancy and use a double pole, double throw toggle switch. The middle would be off, one direction low and the other direction high. Ground the middle terminals. Hook the low wire to both outside terminals of one pole and hook the high wire to one outside terminal.
You could also get fancy and use a double pole, double throw toggle switch. The middle would be off, one direction low and the other direction high. Ground the middle terminals. Hook the low wire to both outside terminals of one pole and hook the high wire to one outside terminal of the other pole.
and if you want to really be simple (though it don't look quite as pretty at the fuse box), you can just insert a jumper wire on the fan relay in the under-hood fuse box. install a switch in the jumper & route it to the cabin.
i just used a piece of speaker wire & put the toggle switch in the center console.
If my car heats up a little more than 240 when it is 110 out should not the fans kick on automatically to bring the heat down ? It will run at 207 on the freeway and around town but it hates to idle for long periods.
Would this switch mod help me out in my situation ?
Those wires will run from the under hood fuse box to the PCM which is under the battery. You'd have to find them at one end or track the harness and open it up to get to them somewhere in the middle. Others have posted you can unbolt and turn the fuse box over to access the wiring under it.
With either mod, would the system operate normally when the toggle switches were in the OFF position or does the install of a overide switch defeat the PCM fan controls?
I have the remote controlled one on my Vette. I know that Saccity also makes a race version where you can run the fans with the car off for drags or autocross. They were also just asking if there might be a market for a hard wired switch. I had replied that I love mine but that if they were to market a hard wired switch I would also like a light to tell me when the high fans are running. They replied that the best thing would be to contact them and they would be able to set me up. I would give them a call it can't hurt to see what they have to say. I'll also add that it was the easiest part that I have installed to date and was well designed.
You simply need to ground connection point E2 on the diagram to turn the fans on in low speed mode or provide power from G2 to E3. I recall seeing a writeup years ago where they removed relay and used a paper clip in the socket for relay 45.
When looking at relay 45 in the fuse box, is E2 in the lower left corner of the relay? (lower being closest to the battery and firewall )
if you do it the way i did, everything works like factory with the switch off & the fans run on high with the switch on. cost me all of $5, don't require any tapping/splicing of wires, and the only irreversible thing was drilling a hole in the console to hard-mount my switch because i wanted it inside the car instead of under the hood.
I want to do a duble pole double throw and have middle as off and one way low and one way on...
am I grabbing from relay 43 as well?
I definitely would like a little more info so I can work this out when I have some free time.
Originally Posted by 8VETTE7
Should be easy to do.
Here is a schematic of the fans:
I really appreciate any help also I jumped relay 45 as instructed in the ranger website and it ended up throwing a check engine code for fan control module 1 .
Hence why I would like to have something permanently hardwired/securely in place. thanks !
i know that sounds cool on paper, but what's the practicality of going through a bunch of extra work simply to run the fan on low? does it really benefit you in some way?
realistically it could only run on high and it wouldnt matter to me...
having it controlled by a switch in the cockpit, very practical for when I race at e-town (often) pre-staging the car culd be ice cold and by the time u get to the line you are at 220 degrees.
