C5 LS1 Engine noise HELP! (with vid)
Old Jul 21, 2013 | 01:08 PM
Grantendo's Avatar
Grantendo
7th Gear
Default C5 LS1 Engine noise HELP! (with vid)
Hey guys, I am relativily new to the LS1 community. I just bought this 99 c5 targa about three weeks ago. After some spirited driving, it started making this noise:
Could it be a bad cat? It has been stalling on me and while we were installing a new exhaust, my friend pointed up that a rattle (like marbles in a tin can) was coming from near the cat. However, this sounds like its coming from the engine. It still makes the noise when I step in the clutch, and when I rev it. Its not really in sync with the revs, but it makes the noise more frequent under more rpms. What could it be??
Thanks guys.
Grant
Old Jul 21, 2013 | 04:48 PM
VinnyT's Avatar
VinnyT
What kind of oil pessure you running when hot?
Old Jul 21, 2013 | 06:59 PM
thepitstop2010's Avatar
thepitstop2010
Any chance the balancer has separated enough to be contacting the steering rack?
Old Jul 21, 2013 | 07:41 PM
Eagle_Gene's Avatar
Eagle_Gene
2nd Gear
it sounds like either a torque tube coupler or a busted flywheel to me???
Old Jul 22, 2013 | 09:24 AM
warlock007's Avatar
warlock007
sounds like the TT, put on lift use stethoscope to pin it down.
also pull the little rubber bell housing piece and with a light look up there and see if anything is loose. engine off first. if its all tight then start and check with scope.
Auto or 6 Speed? auto very possible the torque hub bolt is loose or fell out
Old Jul 22, 2013 | 07:03 PM
Grantendo's Avatar
Grantendo
7th Gear
Thanks for all your replies! It turned out to be a bad water pump. I pulled it out and there was a big puddle of water. In the process of putting a new one on now.
To C5 LS1 Engine noise HELP! (with vid)
