Need help codes after header install
Old Jul 22, 2013 | 10:17 PM
TspopsZ's Avatar
TspopsZ
Default Need help codes after header install
Installed some new OBX long tubes on my 01Z, after the install I'm getting codes P0134 and P0154, i checked for leaks and don't see any (there was one after the install but its gone now and the odes have been cleared and since come back) do I need some special O2 sensor
Much appreciated
Old Jul 22, 2013 | 11:05 PM
TspopsZ's Avatar
TspopsZ
Fuse 15 is not blown and the car idles, accerlaretes and generally runs great car has been tuned already is it safe to have these codes disabled?
Old Jul 22, 2013 | 11:30 PM
dan1546's Avatar
dan1546
Catted x-pipe? You need to have those tuned out most likely, it is not a problem with the install or a leak it's the rear o2 sensors.
Old Jul 22, 2013 | 11:32 PM
baxsom's Avatar
baxsom
does the OBX have rear places for the o2 sensors to be installed? Did you cross the fronts?
Old Jul 23, 2013 | 07:34 AM
TspopsZ's Avatar
TspopsZ
I dont believe they are reversed, but can double check again, there isn't a chatted x pipe but the header do have bungs for rear O2 sensors which have been blocked off to prevent leaks and the rear O2s have been programmed out
Old Jul 23, 2013 | 09:26 AM
hamhead's Avatar
hamhead
Those are front o2 sensor codes.
You need to have front o2 sensors installed, otherwise your car will not run properly. Modern cars use the front o2 sensors to determine proper A/F ratio.
You were supposed to extend the front o2 sensors to where you blocked off the bung on the header and just leave out the rear o2 sensors.
Old Jul 23, 2013 | 09:45 AM
RonSSNova's Avatar
RonSSNova
Both codes are front O2 sensor insufficient activity.
You really can't cross the fronts.
New sensors or the originals?
If original, I'd try new GM parts and see what happens. Amazon has good prices. GM switched designs and they should be faster reacting.
Ron
Old Jul 23, 2013 | 10:59 AM
wcsinx's Avatar
wcsinx
You're getting insufficient activity codes from the front sensors because they're running too cold now. The stock placement of the front sensors on the exhaust manifold has them much closer to the exhaust ports. When you move them downstream to the collector, they don't get hot enough.
The solution is to run the rear type of 02 sensor in the front bungs because the rears have a stronger internal heater. This will require a wiring conversion harness.
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1-A
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1-A
Old Jul 23, 2013 | 12:27 PM
hamhead's Avatar
hamhead
For what its worth, both my car and a friend I did an install for run front o2 sensors with extensions and have no problems. Several kits to my knowledge provide front extensions rather than conversion harnesses for the rear and I haven't heard of widespread problems.
For him to have them both show dead when several cars including my own have no problems with the fronts extended makes me think they aren't plugged in or were soldered incorrectly instead of extended with a harness rather than not heating up properly.
Old Jul 23, 2013 | 01:06 PM
wcsinx's Avatar
wcsinx
I've no doubt there are some systems that will work that way, but it's hit or miss and will depend on the specific design of the headers. LG specifically recommends using the rears in the front position for example.
That's the thing though. They aren't showing dead. They're showing insufficient activity (slow switching) which can be symptomatic of them running too cold. And keep in mind this happened to both at the same time following a header install.
Old Jul 23, 2013 | 01:12 PM
hamhead's Avatar
hamhead
Going off the OBD website, it states this code means no activity. Same for the other.
I'm not sure where you pulled your line definition from, or if there are even two codes that distinguish between no/low voltage for front o2s within the general OBD-II trouble codes themselves, but that site is what I usually go off of.
Old Jul 23, 2013 | 01:26 PM
wcsinx's Avatar
wcsinx
From the service manual
Though interestingly enough, I see slow response codes as well, so maybe GM is redefining "insufficient". But I still maintain that running them cold could cause this code to get thrown.
first sentence of the diagnostic procedure from your link...
"First start the engine and bring it up to operating temperature and ensure the engine reaches closed loop."
Old Jul 23, 2013 | 01:28 PM
hamhead's Avatar
hamhead
I don't disagree.
Best to wait for OP. If he has them plugged in and installed correctly, chances are they both didn't coincidentally "go bad" at the same time and he should use the rear sensors.
Cheaper that way too - just have to buy the adaptor harnesses for $20 each rather than forking out $60 each on new sensors.
Old Jul 23, 2013 | 01:37 PM
wcsinx's Avatar
wcsinx
I don't disagree.
He could just bubba together a temporary adapter harness and use one his existing rears. Then if the code goes away for that side, he'll know that's the problem.
Old Jul 23, 2013 | 03:41 PM
RonSSNova's Avatar
RonSSNova
Wouldn't you think it would be wise to have his tuner just look at the activity? It's easy with the tuning software. You get a graphical representation of the switching.
To me, insifficient activity isn't the same as no activity. Hard to say how the GM software defines it.
I would also wonder if the car is ever going closed loop? Also easy to see with the software. I would guess that at other than idle, it is, but I don't have the car in front of me to look see.
As far as the rears having stronger heaters, I measured heater current for both front and rear sensors from my car and they draw identical current at 12v supply, I believe the heaters are the same.
Would be nice to see a photo of the OBX headers and see just how long they are. I run XS Power headers (same length as AR) with the new design O2 sensors and have no issues.
By the way, the later style O2 sensors are planar style (they heat easier) as opposed to the thimble style of the earlier ones. Planar and Thimble refer to the ceramic substrate material inside the sensor.
Ron
Old Jul 23, 2013 | 04:46 PM
wcsinx's Avatar
wcsinx
I think it depends on the year.
http://www.lgmotorsports.com/gallery...structions.pdf
The early cars have a weak heater in their front sensors. We have found best results to use the rear sensors in the front location by using the supplied adapter harness. Rear sensors should be removed inside the computer or a new set of rear sensors should be used in the rear location.
Old Jul 23, 2013 | 05:11 PM
TspopsZ's Avatar
TspopsZ
i think im going to try new 02 sensors... i also emailed OBX (awaiting response to see if this a common problem for thier headers)
To Need help codes after header install
Old Jul 24, 2013 | 12:13 AM
RonSSNova's Avatar
RonSSNova
Hmmm, mine is a 2000 and the sensors were stock.
I don't know if the various years used different sensors. I have never heard that they do.
Old Jul 24, 2013 | 08:23 PM
Russ K's Avatar
Russ K
Those are very common codes when LT Headers are installed. Just set them to no error reported & uncheck the ses box. Also you will likely also get codes P0133, P0153, P1133, P1153, P1134 and P1154. Just delete them as well.
Russ Kemp
Old Jul 31, 2013 | 01:34 AM
RonSSNova's Avatar
RonSSNova
OP,what did you end up doing?
