Need help on tire size
Front wheels are 17" x 8.5" with +58mm offset and backspacing is 7". Total wheel width is 9.5". Rear wheels are 18" x 9.5" with +65mm offset with and backspacing is 7.5". Total wheel width is 10.5".
Note the front and rear tire size diameter below. You should stay as close as possible to the one inch difference in diameter of the front and rear tires
(stagger) to avoid any possible problems with active handling.
stock
245/ 45 -17 25.7" diameter 4.3" sidewall
275 /40 -18 26.7"diameter 4.3" sidewall
Stagger 1"
295/ 35 -17 26.1" diameter *4.0" sidewall
255 /40-18 25.0" diameter *4.1" *sidewall
Stagger 1.1"
255/45-17 26.1" *diameter 4.5" sidewall
285/40-18 27.0"*diameter 4.5" sidewall
Stagger .9"
255/40-17 25.0"*diameter 4.0" sidewall
285/35-18 25.9"*diameter 3.9" sidewall
Stagger .9"
Little lower profile for looks and a touch wider.
but realize, not all brands have the same tread width...... e.g., a Bridgestone PP or a Kuhmo MX have significantly wider tread than, say, a Goodyear D3.
go to the tire rack and check out the specs
I would not go much wider than a 285 on the rear tire, pushing the stock rim width size a little. Also watch the sidewall or profile height. You may not like too low or too tall of a profile or a different profile size from front to rear.
Here is a handy tire size calculator I think I picked up on Toque's website.
http://www.rimsntires.com/specs.jsp
Personally I went with Nitto Invo in stock sizing
