ls2 in my c5 belt problems
Old Jul 29, 2013 | 09:30 PM
shift-speed's Avatar
shift-speed
Default ls2 in my c5 belt problems
ok so i installed a ls2 in my c5 a few years back but i have a belt noise
i replaced the belt once. i used all the c5 bolt on parts. i may have just a cheap belt. my question is should i use a ls1 belt or ls2 belt. they have two different part number and the ls2 cost twice as much .
Old Jul 29, 2013 | 10:16 PM
thepitstop2010's Avatar
thepitstop2010
Use the ls1 belt since you are using the ls1 accessories. Goodyear gatorback is your best bet. Also double check your balancer bolt and the balancer itself.
Old Jul 29, 2013 | 10:20 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
I had a belt noise too, until I replaced my balancer. Also a slight vibration, also cured.
Old Jul 29, 2013 | 10:31 PM
shift-speed
i will try that belt. the balancer is new with the engine
Old Jul 30, 2013 | 02:48 PM
tlove32's Avatar
tlove32
Are the tensioner and idler pulleys new? They wear out over time and cause the belt to squeal.
Old Jul 30, 2013 | 05:54 PM
gotz06?'s Avatar
gotz06?
Gatorback
To ls2 in my c5 belt problems
