Service Vehicle Soon
Old Jul 30, 2013 | 11:41 AM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Service Vehicle Soon
I am getting this message "Service Engine Soon". I have owned and worked on this car since 1999 and don't recall ever receiving this message before. Anyone know what this generally means?
Old Jul 30, 2013 | 01:58 PM
tycksena's Avatar
tycksena
I am in the same boat. I pulled the codes and got p1637 charging fault. I found a loose wire at the starting solenoid tightened it and the code went away for 2 days but its back. Mine has also been paired with a high voltage from the alternator, have u experienced that?
Old Jul 30, 2013 | 05:10 PM
CapeCodCoupe
Default Code 1281 Active Handling Sensors Uncorrelated
Any one know what to do about this fault. I reset it and went for a ride and it came right back.
Old Jul 30, 2013 | 06:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
mine came on years ago....it still comes on after the new motor
Old Jul 30, 2013 | 06:43 PM
CapeCodCoupe
Default Service "Vehicle" Soon is the message on the DIC
Thanks for your help! There were no other fault codes! Guess what...this is a early 98 and it does not have active handling! It does have traction control. I have been sporting around with the traction control "off". I have had the vehicle in storage for many months with a battery tender while I was in Florida. This past week I put it up on jack stands and installed a Curt hitch receiver so I can haul our bicycles around. I shall go for a ride tomorrow and put the traction control "on" to see what happens!
Old Jul 30, 2013 | 08:50 PM
thepitstop2010's Avatar
thepitstop2010
Is it "service vehicle soon" or "service engine soon"? You stated both. Just trying to clarify. Service vehicle soon usually indicates a exterior bulb is inoperative.
Old Jul 31, 2013 | 09:58 AM
CapeCodCoupe
Default DIC Message
It is indeed "Service Vehicle Soon". I will check for exterior light failure. Thanks
Old Jul 31, 2013 | 05:43 PM
pewter99's Avatar
pewter99
Originally Posted by 8VETTE7
Your what came on??? Service Engine Soon??? or Service Active Handling???
I can understand your Service Engine Soon coming on with that funny looking thing on top of the block where your intake manifold used to be...
Service Vehicle soon....came on over 60K ago....car has been tuned, retuned, modified and then a whole new motor and tuning....message is still there
Its part of my startup procedure...I clear that message and Service Tire Monitor every time...of course I haven't had TPMS since the 2nd set of tires either
Old Jul 31, 2013 | 06:26 PM
ZeeOSix's Avatar
ZeeOSix
Here's all the Owner's Manual says:
"SERVICE VEHICLE SOON: If this message appears
on the DIC, there may be an electrical or another system
problem with your vehicle. Have your vehicle checked
by your dealer if this message keeps appearing."
Like others have said, check for DTCs and go from there. Not sure what the full blown factory Service Manual says about "Service Vehicle Soon".
To Service Vehicle Soon
