This is EXHAUSTING! (pictures inside)
Old Jun 28, 2002 | 07:02 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default This is EXHAUSTING! (pictures inside)
After reading that some C5 exhaust systems are breaking off at the flange where the muffler assembly bolts to the H-pipe assembly, I thought it was just an isolated problem. WRONG!
I went out to check my 99 and guess what? My driver's side exhaust was broken too. I unbolted the mufflers and lowered the cat/h-pipe assembly and here's what I found.
Cute huh? It looks like the weld didn't stick. The weld itself didn't crack. Check it out.
My dealer tells me that he's replaced about 15 sets of these so far. It's always the left side that breaks according to him. GM is paying for them so far. The dealer thinks that there *may* be a recall since this is an emissions related problem. The cats I guess?
Whatever. I took this time to install the Corsa x-pipe. I was planning to install the complete Corsa Indy system anyway. Here's what the Corsa X-pipe looks like if you're curious.
This Corsa piece looks very well made and fits perfectly. I recommend it if you want to replace your defective GM H-pipe assembly. I bought mine from Xtreme Motorsports. (a Forum vendor)
Go out in the garage now and shake your left muffler. If it's MUCH looser than your right, you too have got problems.
Tom
[Modified by TCW, 7:50 PM 6/28/2002]
Old Jun 28, 2002 | 07:25 PM
jschindler's Avatar
jschindler
Default Re: This is EXHAUSTING! (TCW)
Thanks for the post and pics to show where to look.
Old Jun 29, 2002 | 11:57 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
The only thing that my car has left of the Exhaust system is the Cats... ;)
Thanks for the Heads up!! :)
vetterdstr :cheers:
Old Jun 29, 2002 | 12:26 PM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: This is EXHAUSTING! (vetterdstr)
Ditto :)
Old Jun 29, 2002 | 02:19 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Hey, it looks like you did this on jackstands in your garage... How difficult was it?
Old Jun 29, 2002 | 05:25 PM
AP's Avatar
AP
Default Re: This is EXHAUSTING! (jschindler)
That sucks ... I think I will have to have it checked out ...
Old Jun 29, 2002 | 05:28 PM
HOCKEY's Avatar
HOCKEY
Default Re: This is EXHAUSTING! (Umrswimr)
Just got my X Pipe.
Old Jun 29, 2002 | 06:04 PM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
Good grief :nonod:
Old Jun 30, 2002 | 09:04 AM
TCW's Avatar
TCW
Yes, I did it in my garage with 4 jackstands. I guess I had the car raised about 2 1/2 maybe 3 feet off the floor. It took longer to get the car up and made safe to be under than it did to actually remove the old system. I didn't have to remove the mufflers so the car only had to be high enough for me to get under it.
Having said that I'll now say that you don't have to completely remove the stock cat/h-pipe system to install the Corsa x-pipe. You can cut the pipes just behind the cats with a "chain cutter". The Corsa x-pipe comes with excellent instructions on how to do this.
Tom
Old Jun 30, 2002 | 11:18 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here is some info on X-Pipe install Click here
To This is EXHAUSTING! (pictures inside)
