wheel combination for a perfect working ABS
here in Europe nobody can help me what combinations are posible:
I use a 9,5" x 18 front and 12" x 19 back with wider fenders.
Now i search for Michelin or Toyo R888 Semi Slicks that are possible.
275-295 front and 325-345 back
Can anybody list me the working combinations for a C5 preferably with less difference in the overall diameter and also in hight difference between front and back.
Like 275/35-18 mit 345/30-19 if it works with the ABS??
THE TRACKTION CONTROL IS OUT IN MY CAR. I USE RACELOGIC
http://www.rimsntires.com/specs.jsp
With a 275/35/18 and a 305/30/19 there would be 2%> -1,8 to stock
With a 285/30/18 and 345/30/19 would be 9%> +5,2 to stock
With a 285/30/18 and 325/30/19 would be 7%> +3,2 to stock
With a 285/30/18 and 305/30/19 would be 6%> +2,2 to stock
What is the maximum difference for the ABS?
steve
I don`t use the tracktion control, so this doesn`t matter.
So what is the maximum difference for the ABS?
Arun wrote:
I have 26" tall tires on the front and 28" tall tires on the back and there are no.issues with ABS.
the stock difference between front 245/45/17 and rear 275/40/18 is 3,8%
With a 285/30/18 and 345/30/19 would be 9%> +5,2 % to stock the, car is 31 mm, 1,22" higher in the back
With a 285/30/18 and 325/30/19 would be 7%> +3,2 % to stock the, car is 25 mm higher, 0,98" in the back
With a 285/30/18 and 305/30/19 would be 6%> +2,2 % to stock the, car is 19 mm, 0,74" higher in the back
What is the maximum difference for the ABS because these are the only ones with Michelin cup semi slick?
What from this three combinations would work, or would work only without tracktion control?
