Rear Handling Question. Technical Help/Experience Needed
Old Jun 28, 2002 | 09:23 PM
dannymin's Avatar
dannymin
Default Rear Handling Question. Technical Help/Experience Needed
Hey guys, I just replaced my rear tires with new OE tires (EMT's) and ever since then it seems that when I corner hard, or take a hard turn at normal Corvette speeds the rear end is now loose and almost wobbly.
My worn tires had bald patches, but I sure as heck felt more comfortable taking a hard turn or corner than I do with these new ones.
Anyone have any insight on this? Do I need to smoke them a little, or is this a balancing issue?
Thanks.
Old Jun 29, 2002 | 12:49 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Rear Handling Question. Technical Help/Experience Needed (dannymin)
New tires do require a brake in period to get the mold release agents off. I might be off here, but 200 miles comes to mind as a general rule of thumb.
Old Jun 29, 2002 | 01:33 AM
barryscott's Avatar
barryscott
Default Re: Rear Handling Question. Technical Help/Experience Needed (pkmoose)
New tires do require a brake in period to get the mold release agents off. .
Hey Now;
Also you might check the pressure in the rear tires. I know sometimes they jack up the psi to over 35 :yesnod:
To Rear Handling Question. Technical Help/Experience Needed
