Help on Trunk Light
Old Aug 3, 2013 | 06:32 PM
Martinez310's Avatar
Martinez310
Veteran: Marine Corps
St. Jude Donor '14-'15,'19
Default Help on Trunk Light
hello everyone i got a question
the trunk light won't turn on every time i open the trunk. they use to turn on now all of sudden it stop. i replace the bulb and still no good. is there a switch i dont know about or did i disconnect something
sorry guys I'm new to my corvette
Old Aug 3, 2013 | 08:57 PM
c6miller's Avatar
c6miller
There is an accessory light fuse on the passenger footwell and a relay, check your owners manual to see where they are and check them.
Old Aug 4, 2013 | 09:01 AM
dadaroo's Avatar
dadaroo
Not knowing what year or model (I assume a convertible from the picture) I am going on FSM wiring for a 2001 Vert. I doubt that there are changes between the years for each model for this feature but that I can check also if needed.
The fuse in question is #29 and the relay is #42.
My car is not at home but the FSM shows 2 lights in the cargo area. If so, on your car are both not working?
Next, if you open the rear decklid (there is a switch in the latch mechanism) do the interior footwell lights in the car come on? If they do come on then I know the fuse and relay are good.
Give me your feedback and we can go from there. If you want to know how the system works and interacts with the BCM send me a PM with your phone number and I can explain, too involved and time consuming to try and write up in a message.
Old Dec 17, 2014 | 11:34 AM
hdrider13's Avatar
hdrider13
5th Gear
Default cargo lights not working
98 c5 hatchback. My footwell lights work but my cargo lights dont. Anyone know why?
Old Dec 18, 2014 | 06:43 AM
dadaroo's Avatar
dadaroo
Have you pulled the bulbs to verify they are good?
To Help on Trunk Light
