Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff
Re: Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff (Gary2KC5)
Gary I understand that but I was surprised that the clutch would be in almost new condition with 30+ passes at the 1/4 mile and street use. :D
Re: Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff (GaryZ06)
I would bleed/flush the clutch fluid for starters:
http://97vette.com/howto/clutchbleed/index.html
Remove all the fluid out of the reservoir with a turkey baster, then wipe all the crap out of the reservoir with a paper towel. Then every few months you can get most of the fluid out of the reservoir with a baster and replace with fresh.
It is a PITA but here is what the reservoir looks like on a 01 Z06 with 16k miles:
The Z peice is a better clutch though and (at least for me) most of the time inspecting a removed clutch is after many miles or one that has been fried.
As long as you weren't spinning the clutch on your launches it shouldn't have been worn too bad after only 12k miles.
It had to be a little shock, though, to see a perfectly good clutch when it was being torn down for a defective one though.
Former Vendor
1 Post
As mentioned, the ZO6 clutch setup may cure your problems, but if you are going to be drag racing alot, I would recommend a Cartech clutch setup. It has about twice the clamping force of your clutch and I think the Z clutch has only about 20% more clamping force. If you are going to spend the money to get in there and change it, I'd spend the $$$ and get a cartech. they also modify the master and get rid of the line restriction at the same time.
Re: Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff (bparker)
Yes - that is the only adjective I can come up with to explain it.. Its like the clutch didn’t let completely loose - but the RPMs stayed up round 4K but the car was on it face decelerating dramatically.. :confused: And the engine "sounded" like it was bogging @ 4K RPMs.. And another thought just came to mind - I never smelled clutch either but I am totaly assuming it was.. Well wth - what could it be?? :smash:
Re: Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff (C5Noir)
Well.. are you ruling the clutch out then?
I have a couple ideas.
Watch your batery voltage while driving around town. Also, watch your voltage the next time you bog down.
Where is your voltage at? Specifically when bogging??
Re: Umm Dude, I think my clutch is going out @ 7K miles.. Sniff Sniff (MelloYellow)
Now, I hope that it lasts and works properly and only time will tell and or another trip to the track..
We'll see..
BP
What would this mean if your RPM's hung at the same position but the car fell on its face? thanks.
