c5 updated sending units? part numbers?
HERE IS THE LATEST BULLETIN FROM GM ON THIS PROBLEM!
SERVICE - ALL CHEVROLET & CADILLAC DEALERS
Subject: 2002-2005 Chevrolet Corvette and 2004-2005 Cadillac XLR Fuel Gauge Is Erratic
Message #: VSS20050445
2002, 2003, 2004, 2005 Chevrolet Corvette and 2004-2005 Cadillac XLR (Y-Body) Fuel Gauge is Erratic
General Motors is in the process of redesigning the fuel tank sending units in both of the subject vehicles. A new part number has been released but it is not yet in stock. Some dealers have attempted to order the new parts 88967315 or 7316 and they have been told that the parts are not yet available. The new parts have an improved ink coating which will provide improved resistance to fuel contamination and correct fuel sender over travel which is the primary cause for the fuel gauge being erratic. Fuel Modules should not be replaced for complaints of erratic fuel gauge. The fuel sender card is the only part required.
Until the new fuel sender cards are available, the 2004 card is available and can be used. Part number 10310028 left side and 10310103 for the right side will operate in all 2002 through 2005 applications. However it does not have the improved ink path. In cases where a customer insists on a replacement part, the 2004 part can be used although it is the same part that is currently in their car. Availability is expected by the end of April. A bulletin will be released with correct part numbers as soon as the parts become available."
There have been notations on the part numbers saying "with improved sender card" for several years now.
