Water pump replacement
Old Aug 6, 2013 | 12:35 PM
jd_black_00's Avatar
jd_black_00
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
Default Water pump replacement
Hi guys,
My water pump started leaking coolant about a week ago, and I'm going to try to replace it tonight. I got a really good how-to writeup off of another forum, and bought a nice set of cable-operated hose clamp pliers to make the job go more smoothly. My question is if any of you have done this job before, and can make me aware of any pitfalls I might encounter along the way? Thanks so much for your help!
~James
Old Aug 6, 2013 | 12:44 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by jd_black_00
Hi guys,
~James
My crystal ball is cloudy this morning and I'm fresh out of Windex. I can't see what year model you're working on.
Old Aug 6, 2013 | 12:46 PM
jd_black_00
I'm sorry, it's a 2000 Coupe with an Automatic trans
Old Aug 6, 2013 | 01:03 PM
LoneStarFRC
OK, that eliminates the paper gasket issue used on the '97/'98 year models (only). You have the later, and most current, metal framed-style gaskets.
Not many gotchas really. If you've ever changed a pump before, then you're aware of mosty what's involved. I would however recommend you either clean (and I mean wire brush the threads) the six pump mounting bolts. You will probably notice some level of rust/corrosion on them and light/superficial is not a problem really. If heavy, or suspect, I would replace them with GM bolts, not some "Joe's Hardware Store" bolts. The quality of materials and the plating on the GM bolts in most cases is far superior. If re-using, just clean them and apply a dab of anti-seize to the threads when re-installing. Same applies to new.
A torque wrench is highly recommended for these bolts. Use one. Steel bolts and aluminum block make this a necessity. Make SURE the bolt holes are cleaned out (no remaining coolant/debris inside) before bolting down and NO gasket sealer of ANY kind is needed on the gaskets. Clean and dry is the ticket.
I recommend using distilled water for the anti-freeze mix on refilling. No minerals, calcium, iron, etc and very cheap. I also recommend staying with Dex-Cool or it's direct equivalent.
HTH
Old Aug 6, 2013 | 01:09 PM
jd_black_00
HTH
Thanks! I bought the Delco Dexcool and distilled water earlier in the week. I always follow the proper torque specs, as I've already learned that so many things on this car thread into aluminum that an easy job can become a nightmare in a hurry! I'll make sure to clean the threads and bolts, and if they look sh***y I'll order some replacements from GM! Hopefully everything goes smoothly, as she needs to make the 180 mile drive up to Road America this weekend!
Old Aug 6, 2013 | 01:18 PM
LoneStarFRC
The bolt numbers are 12551926 if you need them.
Btw, one other tip. When re-installing the main (six groove) belt, first get it in all the pulleys, etc and while putting pressure on the tensioner, slide the belt over the WP hub pulley last. Makes it easier.
To Water pump replacement
