Drivers window problem......
Old Aug 8, 2013 | 04:27 AM
projectcop's Avatar
projectcop
Default Drivers window problem......
Hi guys;
I've been hearing too much wind noise lately on the drivers side at highway speeds. Also noticed during high cross winds, the window pulls away from the weatherstripping and I can see between the glass and rubber.
Also noticed when rolling the window down, it makes a clunk sound that sounds as if the glass is stopping against something metallic when it hits bottom.
Is there an adjustment I can make to fix this, or do I need a new regulator?
Old Aug 9, 2013 | 10:49 AM
TEXHAWK0's Avatar
TEXHAWK0
Normally making the glass fit against the weatherstripping is just an adjustment, but since you also have a noise, I would suggest you take the door panel off and see if anything is broken on the regulator assembly.
It is a good sign that the window still goes up and down, but it should not be making noise when it hits the stops.
