Coolant Temp at 228?!
Old Jun 29, 2002 | 05:07 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
Default Coolant Temp at 228?!
Okay, this can't be good. Pulled into the local Dairy Queen today and the coolant temp was 198 or so when I pulled in. After I sat there in the drive through for a minute or two, it was up to 228, and then started fluctuating between 217 and 228. I never heard the fans kick on either which is sort of odd.
Guess I will start with the connection to the fans and make sure they are connected. Any other ideas.
The thermostat was obviously opening or the temp would have kept going higher and higher, although, it may be opening at a higher temp for some odd reason.
Thanks in Advance,
Old Jun 29, 2002 | 05:20 PM
Skeeter1's Avatar
Skeeter1
Default Re: Coolant Temp at 228?! (CrazyMagMan)
thats not too too high, what was the outside temp ?
Old Jun 29, 2002 | 05:29 PM
HOCKEY's Avatar
HOCKEY
Default Re: Coolant Temp at 228?! (Skeeter1)
What is normal for the temp to be?
Old Jun 29, 2002 | 05:37 PM
CrazyMagMan
St. Jude Donor '05
Default Re: Coolant Temp at 228?! (HOCKEY)
Normally when cruising it is around 187, but have noticed when parked it spikes up rather quickly.
The outside temp was 91.
Old Jun 29, 2002 | 05:47 PM
Oldvetter's Avatar
Oldvetter
That's okay, fans don't come on until 230-239 F
Old Jun 29, 2002 | 09:13 PM
CP's Avatar
CP
Default Re: Coolant Temp at 228?! (Oldvetter)
If it cycled like that, the fans were definitely kicking on.
To Coolant Temp at 228?!
